Fitment of OEM luggage - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 3 Post By We2V2
post #1 of 4 Old 03-30-2016, 09:00 PM Thread Starter
pats's Avatar
Who still uses their Suzuki luggage, and do you have additional ways of keeping it from going airborne? I have yet to load mine, so they seem vulnerable at highway speeds. I have considered a bungee of some type to keep the handles locked down and down pressure to keep them in the mounting brackets. Anyone using the luggage and any thing more than just the single center tab slider to anchor them?
pats is offline
post #2 of 4 Old 03-30-2016, 09:11 PM
We've used our luggage for 7000 kilometres and some of that was on VERY bumpy tracks! Its has never even hinted at coming adrift.
The handles are locked down securely when you remove the key
Yamaha use the same system now also with their factory side panniers.
Only advice we can give is put all your stuff in a sports bag or duffle etc and put that inside the pannier, and use the internal straps that hold the stuff in. These panniers are VERY fussy about not being over stuffed or the lids not closing exactly right.
This is good insurance that ensures they are closed securely. If the latches or key are stubborn, open the pannier and check the door aperture for any clothing or obstructions
The mechanisms, though a bit stiff, are reliable and secure.
Also we have had them is pissing rain and dust- no leaks of any kind
They are good panniers
Jason709, Tefloncandy and kustard like this.
Paul and Dixie and our V2
DL1000A 2015. SW-Motec crash bars and skid plate,Givi Airflo screen,Givi rear Hugger,Factory low seat,Barkbusters with Storm guards,Factory Tank Protector, Factory centre stand,RadGuard Radiator Guard,home made top box adaptor plate with poverty top box,Factory hard panniers,Zumo390LM,TKC70's,windshield lowered 50mm with custom mounting plates,motopressor tyre inflator,Virgins breath in the tyres,Barrett exhaust,AWESOME rider and pillion.
We2V2 is offline
post #3 of 4 Old 03-31-2016, 10:50 PM
I'm assuming you're talking about the side cases. They should be on there really tight when you latch down the handle and lock it. I believe the metal bracket the handle latches onto is adjustable horizontally, so maybe those bolts just need to be loosened and that bracket moved until you get a snug fit.
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #4 of 4 Old 04-01-2016, 10:07 PM
Agree G-Dub. They should be tight and secure, so an adjustment may be in order. I have 8k miles and still good.
MrMagoo is offline
