Switched source for GPS - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 10Likes
post #1 of 25 Old 03-28-2016, 04:34 PM Thread Starter
pats's Avatar
Any suggestions? Do not have a owner installed extra fuse block. Is a tap con crimp overtire style ok? Is 3 amp enough power? dl1000
pats is offline
post #2 of 25 Old 03-28-2016, 05:23 PM
NSdave's Avatar
I used the tail light adapter from Easter beaver.
14' DL1000
NSdave is offline
post #3 of 25 Old 03-28-2016, 08:37 PM
kustard's Avatar
I've tapped into the accessory outlet line, I just removed the instrument cluster and used a posi-product crimp of the appropriate size/amperage. I don't use the accessory outlet so the wiring is enough for my power needs.
richlandrick and Tefloncandy like this.
Suzuki DR650 (2016) - Grey
Yamaha XSR900 (2016) - Blue
Sadly deceased: Suzuki VStrom DL1000 (2014) - White
Shiro Suzuki shijūha~tsu 白スズキ四十八 (White Suzuki forty-eight)
The Adventures of 69SIM - https://www.youtube.com/channel/UCzK0IIM_4zZjC3DF95GIBKA
kustard is offline
post #4 of 25 Old 03-29-2016, 03:21 AM
V2man's Avatar
We have used the Eastern beaver tail light harness and a PC8 for switched power.
Cheers V2man & GotaV2
kustard likes this.
2014 DL1000A 2014 -
2012 DL650L2 2013 - 2014
2007 DL1000 "Bowser" 2009 - 2013
V2man is offline
post #5 of 25 Old 03-29-2016, 10:13 AM
Tefloncandy's Avatar
I did the same thing and it works like it should.
kustard likes this.
13' KLR 650, 06' GL1800
"No good decision was ever made in a swivel chair" George S. Patton
Tefloncandy is offline
post #6 of 25 Old 03-29-2016, 10:29 AM
ToadRide's Avatar
Same, same.
kustard likes this.
ToadRide is offline
post #7 of 25 Old 03-29-2016, 09:09 PM Thread Starter
pats's Avatar
How is the panel, or wires to the acc. Plug accessed? Dl1000 2014
pats is offline
post #8 of 25 Old 03-29-2016, 11:09 PM
Maybe I'm not clued in to some detail, but why wouldn't you just use the built-in 12 volt accessory socket?
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
post #9 of 25 Old 03-30-2016, 01:53 AM Thread Starter
pats's Avatar
I have not yet received the GPS so unaware if it has the plug in for the female cig lighter also I have heard that it tends to vibrate loose.
SO THE NEED to tap onto a hot wire, so they Sa?
pats is offline
post #10 of 25 Old 03-30-2016, 10:29 AM
Typically, GPS units with cigarette socket plugs have a 5VDC voltage regulator in the plug. If you just cut off the plug and connect the wires to 12VDC, bad things may happen.
richlandrick likes this.
