HELP - oil leak! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
  • 1 Post By Rolex
  • 1 Post By strominateacup
post #1 of 9 Old 03-25-2016, 06:18 PM Thread Starter
Ago
Ago's Avatar
HELP - oil leak!
For some unknown reason, today I decided to clean the area around the front sproket (which BTW wasn't very dirty because I had cleaned it last fall.)
After I put everything back together I start the bike and – HOLY CRAP!! – there is oil dripping from just below the clutch slave... I checked and it was engine oil, not clucth/brake fluid.
SO I took everything apart again and looks like the oil was coming from the push rod - quite a bit of it too!
I cleaned everything, put it all back together, start the bike and... no leak. I even went for a short ride and everything seems fine.
What the heck did I do?! Any idea what could have caused the leak?
Ago is offline
post #2 of 9 Old 03-25-2016, 06:58 PM
Scott E. Bonds's Avatar
Grit in the push rod seal.
2007 Blue SuperVee 1000
2000 Red Honda XR 400r
Scott E. Bonds is offline
post #3 of 9 Old 03-25-2016, 07:02 PM Thread Starter
Ago
Ago's Avatar
Hmm, must have been a lot of grit... it was leaking quite a bit.
But if that's all it was then I guess it got 'cleaned out' when I took it apart the second time, so I shouldn't worry about it.
Ago is offline
post #4 of 9 Old 03-25-2016, 07:22 PM
Sgt Schultz's Avatar
Your first mistake was cleaning the bike
But yes maybe a bit of grit got into the seal when you cleaned it up. Did you just wipe over the dirt or use any pressure wash on it?
It's amazing how much grease and road dirt collects around that area.
I know nuffink, I see nuffink, It was not me, I was not here.
IBA #45920
FarRider #299
2015 Wee Strom "Piglet"
Givi crash bars, Barkbusters, Ravetech Bash plate, Ravetech Rad guard, Ravetech over dash Ram mount, Hyperlite flashing brake lights, Madstad bracket and screen, Augustus wind deflectors, Spot 3, UHF two way radio, Garmin Zumo GPS, Starcom intercom, Fuze block.
SW Motech Centre stand, Suzuki power outlet. Bike Alarm, Screaming Banshee horn, Led Flood lights, Tool tube, Andy Strapz Expedition soft panniers and frames.
Sgt Schultz is offline
post #5 of 9 Old 03-25-2016, 07:29 PM Thread Starter
Ago
Ago's Avatar
No, no pressure... I actually didn't have to do much cleaning as the area was already qute clean.
Maybe the push rod didn't go in properly when I re-mounted the slave.
I'm just surprised that it could start AND stop leaking so easily. Never had that happen to me before.
Ago is offline
post #6 of 9 Old 03-25-2016, 07:54 PM
Be sure you are leaving the piston rod in the seal when you clean, otherwise gunk and cleaner will get into the seal and into the clutch. Not sure exactly what happened.....quite peculiar.
post #7 of 9 Old 03-25-2016, 09:17 PM
Rolex's Avatar
The push rod seal can move very easily, it can be pushed into the motor as there is no stop behind the seal.
Use hook to pull the seal back into place.
When putting things back together ensure you fit the rod first, check the seal is in place then fit the slave cylinder.
I built a seal saver to keep the crud off my rod and out of the seal.
Bugzy likes this.
Rolex is offline
post #8 of 9 Old 03-25-2016, 09:52 PM Thread Starter
Ago
Ago's Avatar
Originally Posted by Rolex View Post
The push rod seal can move very easily...
I must have ー somehow ー installed the pushrod incorrectly, and that might have ー somehow ー changed the position of the seal, causing it to let oil pass through.
When I then removed the slave, pulled out the pushrod and put it back in place it must have ー somehow ー re-aligned the seal. No more leak.
That's the only logical explanation I can think of. Hopefully I didn't cause any damage that is going to sneak up on me later on!
Ago is offline
post #9 of 9 Old 03-25-2016, 11:04 PM
strominateacup's Avatar
1. It's not leaking now.
2. If it ain't broke, don't fix it.
3. Don't worry, be happy!
Sgt Schultz likes this.
There are holes in the sky where the rain gets in,
and the holes are very small, that's why rain is thin.
Spike Milligan.
strominateacup is offline
