For some unknown reason, today I decided to clean the area around the front sproket (which BTW wasn't very dirty because I had cleaned it last fall.)
After I put everything back together I start the bike and – HOLY CRAP!! – there is oil dripping from just below the clutch slave... I checked and it was engine oil, not clucth/brake fluid.
SO I took everything apart again and looks like the oil was coming from the push rod - quite a bit of it too!
I cleaned everything, put it all back together, start the bike and... no leak. I even went for a short ride and everything seems fine.
What the heck did I do?! Any idea what could have caused the leak?
Hmm, must have been a lot of grit... it was leaking quite a bit.
But if that's all it was then I guess it got 'cleaned out' when I took it apart the second time, so I shouldn't worry about it.
Your first mistake was cleaning the bike :grin2:
But yes maybe a bit of grit got into the seal when you cleaned it up. Did you just wipe over the dirt or use any pressure wash on it?
It's amazing how much grease and road dirt collects around that area.
No, no pressure... I actually didn't have to do much cleaning as the area was already qute clean.
Maybe the push rod didn't go in properly when I re-mounted the slave.
I'm just surprised that it could start AND stop leaking so easily. Never had that happen to me before.
Be sure you are leaving the piston rod in the seal when you clean, otherwise gunk and cleaner will get into the seal and into the clutch. Not sure exactly what happened.....quite peculiar.
I must have ー somehow ー installed the pushrod incorrectly, and that might have ー somehow ー changed the position of the seal, causing it to let oil pass through.
When I then removed the slave, pulled out the pushrod and put it back in place it must have ー somehow ー re-aligned the seal. No more leak.
That's the only logical explanation I can think of. Hopefully I didn't cause any damage that is going to sneak up on me later on!
1. It's not leaking now.
2. If it ain't broke, don't fix it.
3. Don't worry, be happy!
Related Threads
StromTrooper
1.7M posts
66.6K members
Since 2003
