Replacement Plastic Throttle Tube? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By billyal33
post #1 of 5 Old 03-24-2016, 10:34 AM Thread Starter
TRM
I wanted a simple (cheap/no grip specific moldings) replacement throttle tube to make grip changes easier and possibly heated grips next winter. I ordered the motion pro based on the image on the website and when delivered is almost exactly like the stock one (Raised edges on both ends of the tube and some raised moldings to match the inside of the grip).
I thought the G2 would be good option, but the reading it seems to require significant modification for heated grips.
Any ideas?
Thanks, TRM
TRM is offline
post #2 of 5 Old 03-24-2016, 10:38 AM
Just grind/file/sand down the ridges on the Motion Pro, I have the same one as a spare.
post #3 of 5 Old 03-24-2016, 01:35 PM
billyal33's Avatar
G2 throttle tamer works fine, lovely smooth action and the vike runs better at low speeds. All you need to do is sand or file down the knurled section of the tube till a heated grip fits on. Oxfords sports on mine
V2man likes this.
billyal33 is offline
post #4 of 5 Old 10-09-2018, 03:58 PM
What is the part number for the motion pro? Is it the Motion Pro Nylon Throttle Grip Sleeve - 01-0094 ?
Thank you!
JD
Jd Elsey is offline
post #5 of 5 Old 10-11-2018, 03:36 AM
V2man's Avatar
The G2 works well, here is how GotaV2 did ours
https://www.stromtrooper.com/2905257-post44.html
Cheers
2014 DL1000A 2014 -
2012 DL650L2 2013 - 2014
2007 DL1000 "Bowser" 2009 - 2013
V2man is offline
