Adventure luggage sloppy fit - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 03-23-2016, 06:47 PM Thread Starter
pats's Avatar
I noticed that the empty bags have a lot of slop,"looseness" after they are attached and empty. Perhaps when weighted it would not be bad but seems like they would shake in the mounts if used empty and over time loosen more. Anyone found a way to get a tight fitment?
pats is offline
post #2 of 9 Old 03-23-2016, 08:43 PM
Tefloncandy's Avatar
You can tighten up the play a little bit by loosening the bolts at the foot pegs mounting points and pulling up slightly on one end. This will angle up the rubber stop a bit and tighten up the mounting. The down side to this is that the bags are a little more finiky to get off if you want to remove them.
13' KLR 650, 06' GL1800
"No good decision was ever made in a swivel chair" George S. Patton
Tefloncandy is offline
post #3 of 9 Old 03-23-2016, 08:48 PM
chicago's Avatar
I used weather stripping once upon a time to stop luggage play. different system though.
14 tooth for me
chicago is offline
post #4 of 9 Old 03-23-2016, 10:43 PM
Mine are tight. Look for ways to adjust the lower mount or any other way to take out some slop.
post #5 of 9 Old 03-24-2016, 03:44 PM Thread Starter
pats's Avatar
OK thanks too cold tomorrow so will try it. Today when looking at that rubber stop I did find that they are factory glued. Metal to rubber and now there is no mechanical fastening left the glue is shot. so if you ride without the luggage you might want to pull the rubber off and put them in a safe place.
pats is offline
post #6 of 9 Old 03-24-2016, 07:50 PM
NSdave's Avatar
there have been a few people, including myself, that had to re-glue the rubbers as a light tug would pop them right off
14' DL1000
NSdave is offline
post #7 of 9 Old 03-25-2016, 05:15 PM Thread Starter
pats's Avatar
ANY IDEAS ON THE BEST GLUE for rubber to steel connection?
pats is offline
post #8 of 9 Old 03-26-2016, 08:40 PM
E6000 is my favorite.
post #9 of 9 Old 03-27-2016, 03:18 PM Thread Starter
pats's Avatar
I found that good ole electrical tape triple wrapped around the hanging arms of the luggage, will fill the need space and tighten up the fit.
pats is offline
