Powerlet Install - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Bugzy
post #1 of 6 Old 03-20-2016, 08:42 PM Thread Starter
pats's Avatar
Powerlet Install
I am going to install a power let on the left side plastic just above knee level for a plug-in for my vest. Should I run the wiring directly to the battery?
pats is offline
post #2 of 6 Old 03-20-2016, 08:57 PM
NyMeTsFaN912's Avatar
Yes. Exactly how the instructions say to. That's what I did and it works perfectly.
-John
NyMeTsFaN912 is offline
post #3 of 6 Old 03-20-2016, 09:00 PM Thread Starter
pats's Avatar
Thanks , Still in the plastic packaging but no instructions.
pats is offline
post #4 of 6 Old 03-20-2016, 09:07 PM
Bugzy's Avatar
I wired mine into a fuse block so it goes off with the key, but you could go straight to battery as long as it's fused.
It is safe since there is no way you can leave the bike with the heated gear still activated and the engine off, just watch you don't stop to talk to someone for half an hour or something.
NyMeTsFaN912 likes this.
Bugzy is offline
post #5 of 6 Old 03-21-2016, 09:54 PM Thread Starter
pats's Avatar
Would you happen to know what size fuze would be correct for the single power source for a vest?
pats is offline
post #6 of 6 Old 03-21-2016, 11:06 PM
Bugzy's Avatar
I believe I have a 15a on it and it hasn't blown yet, but I rarely run the vest at max temps as it is too hot.
Bugzy is offline
