V2 - Hard shifting into 3rd gear - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
post #1 of 41 Old 03-19-2016, 08:59 AM Thread Starter
Zig-Zag's Avatar
Unhappy V2 - Hard shifting into 3rd gear
Hello, I just picked up my new '14 V2 last Tuesday. I really like the way it rides and handles but there's a problem. Sometimes it won't shift into third ( and sometimes 4th ) gear. I've been riding for quite a few years so I'm very sure it's not operator error. I rode the bike to Suzuki of Dalton (great people), and their mechanic rode the bike for 20 minutes. It shifted perfectly. It's been a intermittant problem and it did it again on my way home.
I'll be taking it in for the 600 mile check and I'm planning on leaving it with them so they can ride the bike and really check it out.
Has anyone else had this kind of problem? What was the fix?
Ride it like you're invisible - Because you are.
Bikes past and present:
1967 Honda 305 Superhawk - Sold
1976 Honda 750 Superhawk - Sold
1978 Velorex sidecar added
1978 BMW R90 (with the sidecar) - Sold
2003 Kawasaki 1600 Vulcan - Crashed
1986 Honda 700s Nighthawk - Sold
2005 Suzuki S50 - Sold
2012 Victory Cross Roads - Keeper
2014 Suzuki DL1000A - Keeper
Zig-Zag is offline
post #2 of 41 Old 03-19-2016, 10:04 AM
tenny80's Avatar
Yes mine was like that stock too, there is an arm that connects to the spline that arm connects to a rod that you use to adjust the gear shifter height along with the position of the arm. The position of the arm should be at 90 degrees. I can take a picture for you if you need further clarification.
V-Tom likes this.
2018 Vstrom 1000
tenny80 is online now
post #3 of 41 Old 03-19-2016, 10:33 AM
V-Tom's Avatar
As Tenny80 says the linkage is the first thing to check. Later on in ownership often that same linkage may need lube but that isn't likely the issue today.
Even though you/we have lots of experience in many cases it is user error.. We all get in habits of shifting certain ways based on bikes we are used to. When we get on a different bike with different ergonomics often we don't move the shifter quite right and as a result have bad shifts.
I haven't had anyone on the back on my DL1000 but I found on the 650's when I had a passenger my sitting position was a bit different and as a result I would occasionally mess up shifts when riding two up (or when carrying really large things in the back seat.)
Assuming the linkage is adjusted properly for you the odds are the problem will disappear or minimize as you get more seat time on it.
..Tom
We2V2 likes this.
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is online now
post #4 of 41 Old 03-19-2016, 10:50 AM
Is this occurring while wearing boots or tennis shoes? Also I have found that the Stroms typically require a pretty firm upshift unless you are short shifting.
post #5 of 41 Old 03-19-2016, 11:46 AM Thread Starter
Zig-Zag's Avatar
Hello, Thanks for the replies.
I adjusted the linkage when I got home and there was no improvement. I always ride with boots and always solo.
I've tried pre-loading the shift linkage before using the clutch and sometimes it still does it. I've shifted fast, slow, and everything in between. The bike has less than 600 miles on it so I haven't wound it up yet.
Also - How do I post pictures on this forum?
Zig-Zag is offline
post #6 of 41 Old 03-19-2016, 11:53 AM
bosnjo's Avatar
Try this:
- When upshifting, try to be as quick as possible and shift it when the clutch is only half way pulled in.
- When downshifting keep some throttle so the engine never goes down to idle rpm. I mean, keep it on 1500rpm or so.
That is just for the sake of testing.
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is online now
post #7 of 41 Old 03-19-2016, 12:17 PM
Bugzy's Avatar
I put my photos on photobucket and then grab the IMG link for them to paste in here. It will look like [ IMG ]http://www.photobucket.com/yourimagelink.jpg[ /IMG ], but without any spaces.
Bugzy is offline
post #8 of 41 Old 03-19-2016, 12:52 PM
Is the shifting problem the same whether the engine is cold or hot??
2014 DL1000 ADV
2006 DL1000 125,000 miles (Sold!!)
Nail34 is offline
post #9 of 41 Old 03-19-2016, 01:48 PM Thread Starter
Zig-Zag's Avatar
It doesn't matter - hot or cold.
Zig-Zag is offline
post #10 of 41 Old 03-19-2016, 02:23 PM
Vstrom N Me's Avatar
I get the clunky shift like the older Vees did going from first to second. Sometimes if I shift at about 3000 rpms, it shifts normally but thats not often. And the bike temp has little efect on it, it seems a little better for the first 500 miles with new oil in it.
Vstrom N Me is offline
