Dash panel removal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 10Likes
post #1 of 24 Old 03-15-2016, 03:06 PM Thread Starter
pats's Avatar
Dash panel removal
I am trying to get into the dash signal indicator bulb. tips? 2014 dl1000
pats is offline
post #2 of 24 Old 03-15-2016, 04:25 PM
stu53's Avatar
The dash turn signal bulbs are LEDs. All the bulbs in dash are.
The manual says to replace the whole meter unit if any of the LEDs in it stop working properly.
DL1000A 2014
previously DL650K6
stu53 is offline
post #3 of 24 Old 03-16-2016, 12:55 AM
Screws, plastic rivets, and hidden plastic clips. Remove the screws & rivets, then pry it off the clips.
post #4 of 24 Old 03-16-2016, 02:16 AM
wackokid's Avatar
When you go to remove the rivets take a small soft nose object that is small enough to fit in the middle of the rivet and simply push on them be able to easily pop them out with your finger nails to remove them. Once you go to put them back in you can pull the center out and then press it flush once the rivet is in place.
Old Time Rider likes this.
wackokid is offline
post #5 of 24 Old 03-16-2016, 03:10 AM
strominateacup's Avatar
Well that's one type of bike I won't ever be tempted to buy.
So the dash is a throwaway item if an led fails! How long before the whole bike is a disposable item if a bulb fails or the aircleaner needs cleaning or a tyre gets worn?
FFS.
There are holes in the sky where the rain gets in,
and the holes are very small, that's why rain is thin.
Spike Milligan.
strominateacup is offline
post #6 of 24 Old 03-16-2016, 03:26 AM
I have never had a dash bulb go out on any bike, so I would imagine that LED are going to last even longer.
post #7 of 24 Old 03-16-2016, 07:33 AM
Agree! My buddy rides a early 80's Kawi KZ, original bulbs. Some folks will find the dark side of anything!
Bville-Bud is offline
post #8 of 24 Old 03-16-2016, 11:42 AM
Bugzy's Avatar
FFS.
The OP didn't say the bulb isn't working, he said he wanted to gain access to it. Maybe he is troubleshooting the switch or something.
Maybe he needs to do the recall first.
Bugzy is online now
post #9 of 24 Old 03-16-2016, 12:05 PM
My guess it has to do with installing a signal minder or auto cancel signals.
Bugzy likes this.
post #10 of 24 Old 03-17-2016, 03:26 AM
The leds may last very well, and the OP may not have a blown one, but if the manual calls for replacing the instrument panel if a light fails, my comments still stand.
Spike Milligan.
