Front tire Removal - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 11Likes
post #1 of 31 Old 03-13-2016, 04:12 PM Thread Starter
pats's Avatar
Front tire Removal
The Owners Manual calls for a special tool for removal of the axle shaft as part of the front tire removal. Is this tool definetley needed or is there a substitute method?
pats is offline
post #2 of 31 Old 03-13-2016, 06:33 PM
Bugzy is offline
post #3 of 31 Old 03-13-2016, 06:48 PM
WeeBee's Avatar
Rick @ Adventure-Tech sells a Front Axle Hex Tool that works with 2002-2013 DL1000's.The tool is cheap at only $4 but shipping as quoted seems a little high for such a small thing. Give them a call and they'll probably re-quote at a lower rate. If your 1000 is newer, they are working on a tool for it.
Specials and Promotions - AdventureTech, LLC.
WeeBee is offline
post #4 of 31 Old 03-14-2016, 12:25 AM
Nope he does not have one yet for the Vee2, but for the rest of us who ride the other year models that is great.
post #5 of 31 Old 03-14-2016, 08:54 AM
Is there not a front axle wrench in the factory toolkit?
blz2dwl is offline
post #6 of 31 Old 03-14-2016, 09:39 AM
It turns out that the sparkplug wrench in my tool kit fits the front axle. However, it is not nearly strong enough to actually remove the axle. Seems like a poor design to me. I carry a huge allen wrench under my seat just for that axle - but I'm considering getting and adapter - like the the adventure tech one - and welding it to the end of the axle. That way I can remove the axle with a wrench and don't have to worry about finding the one specialty tool I need.
motopsycho is offline
post #7 of 31 Old 03-14-2016, 09:44 AM
Ago
Ago's Avatar
Nope! Neither front nor rear wheel removal tools in the toolkit.
The factory toolkit is really not much of a 'tool kit'.
Ago is offline
post #8 of 31 Old 03-14-2016, 11:58 AM
NVDucati's Avatar
You can always just pick up a nut that fits in the axle and use a conventional wrench on the nut.
Bugzy and flgolfer29 like this.
Member: AMA
NVDucati is online now
post #9 of 31 Old 03-14-2016, 12:31 PM
Bugzy's Avatar
The axle size is 24mm in case you need to know.
Bugzy is offline
post #10 of 31 Old 03-14-2016, 03:21 PM
stromer's Avatar
Is it the same hex type as on the Glee?
just give it a little gas, it will be ok !!!
stromer is offline
