ECU Swap Information - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 9Likes
post #1 of 29 Old 03-12-2016, 04:41 PM Thread Starter
York's Avatar
Exclamation ECU Swap Information
(Please visit the following thread too and take part https://www.stromtrooper.com/dl1000a-...have-done.html )
Here are some ECU swap information from Germany, which is not a recall but it's being exchanged on warranty. So far 89 members got it replaced as of 3/12/16. http://www.v-stromforum.de/viewtopic...3607&start=360
The website of Reinhard also provides a lot of information about his power loss. He says his dyno results started Suzuki's ECU investigation and that Suzuki informed officially all dealers on August 4th 2015 about the ECU problem. Effected are 3 out of 10 early DL1000A L4 (and I believe L5). Culprit is the ECU J00 and J01, which were replaced with J02
source: extremes Drehmomentloch | on2r.eu
ECU J01 got rid of the power drop in 2nd gear and the 3rd gear had more torque in lower RPM. No more stalling.
ECU J02 killed the violent vibration in 2nd gear at low RPMs still present with J01. It felt like the bike was trying to shake off its front end when driving in 2nd below 1500 RPM (about 25km/h). Now even at 1200RPM in 2nd the engine runs smooth.
Dyno test result:
Best rider's feedback so far after ECU swap:
- Bike sometimes dies after cold start.
Didn't happen anymore! Idle speed is a tap higher!
- Occasionally misfire.
Not anymore!
- Below 50km/h had to shift into 3rd gear because engine wouldn't run smooth and would start to jerk.
Now even in 5th gear and 50km/h smooth without jerking! Also the acceleration from 50km/h in 5th gear is without jerking!
- With traction control setting either in 1 or 2, the engine would 'have to climb out of the basement' when accelerating in 2nd or 3rd gear. When accelerating out of a corner or when overtaking power loss was felt. Had to close throttle and slowly increase speed to control the weird loss of power.
Now merciless acceleration and the traction control light is blinking!
ECU repair time:
Dealers with no knowledge try to put of customers saying the swap would take an entire day. However it is being reported that the swap takes about 15min.
- short test drive
- seat off
- disconnect battery
- swap ECU
- connect battery
- program both ignition keys
- seat back on
- reset clock
- test drive
source: http://www.v-stromforum.de/viewtopic...43607&start=15
According to the Suzuki parts list the ECU unit for 2014 and 2015 got changed. (have not seen a 2016 parts list yet)
ECU part# source: 2015 Suzuki DL1000A ELECTRICAL (DL1000AL5 E03) | Babbitts Suzuki Partshouse
ECU/CONTROL UNIT, FI was 32920-31J10 and got replace with the new part# 32920-31J11 for the following bikes
2014 (DL1000AL4 E03 ) - U.S.A except for California
2014 (DL1000AL4 E28 ) - Canada
2015 (DL1000AL5 E03 ) - U.S.A except for California
2015 (DL1000AL5 E28 ) - Canada
was 32920-31J20 and got replace with the new part# 32920-31J21 for the following bikes
2014 (DL1000AL4 E33 ) - California
2015 (DL1000AL5 E33 ) - California
It will be interesting to know if all the issues (stalling, power loss etc.) only occur with the first ECU version.
Therefore please include the information below when you take part or already have taken part in the poll.
With the ORIGINAL ECU
List your ECU version (J10, J11, J20 or J21):
List your bike's problems:
How to reproduce the issue(s)? -for someone who is unsure about his bike-
With the NEW REPLACEMENT ECU
List your new ECU version (J10, J11, J20 or J21):
State the result after ECU swap:
Address of who performed the ECU warranty work:
STROMTROOPER Poll:
https://www.stromtrooper.com/dl1000a-...ml#post3838873
DL1000A Country Codes:
E03 U.S.A except for California
E28 Canada
E33 California
E14 Thailand
E21 E.U.
E24 Australia
E50 China
E99 Other Countries
Vaseface and StromHK like this.
Ride - Life Is Too Short!
York
York is offline
post #2 of 29 Old 03-12-2016, 05:41 PM
I have just purchased a 2014 model in Ontario, Canada and eventually got a response from Suzuki Canada. They stated that the ECU in Europe is different to the one used in Canada. They also stated that if you do have an issue it would be replaced under warranty.
oldton43 is offline
post #3 of 29 Old 03-12-2016, 11:13 PM
You know that bike has a first gear, don't ya?
yesbut likes this.
2014 DL650 (sold)
2014 DL1000
mcrag is offline
post #4 of 29 Old 03-13-2016, 06:25 AM
bosnjo's Avatar
I live in Portugal.
My ECU was J00 and was replaced by J02.
I believe and can confirm a lot of mentioned in previous post, stating German experiences...
BUT...
talking about 1200 or 1500 rpm vibrations ???
At those rpm my bike would disintegrate, I guess... C'mon, it's V-twin!!
Nail34 likes this.
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
post #5 of 29 Old 03-14-2016, 05:10 PM
triman11427's Avatar
I just got off the phone with Suzuki USA to discuss and document the stalling issue. After reading a variety of posts that confirm Germany, Portugal and several other countries have swapped to newer ECU's, I wanted to know if thats a possibility in the US and whether the USA corporate offices were even aware of an issue. The customer service rep was very attentive and took note of the conversation. I'm hoping some action will be taken in that this apparently is not a unique situation to me. Before I go for X-TRE or some other flash product, I'd like Suzuki to make this right. This really is a plug and play install and aside from the cost of the unit (which I suppose is significant) it's far less costly than being held accountable to a possible accident when a bike stalls while crossing traffic.
Bugzy likes this.
triman11427 is offline
post #6 of 29 Old 03-14-2016, 08:27 PM
gtmn's Avatar
what number for Suzuki customer service
I cant find one I would love to follow up with my own calls
these bikes should run better then they do
1975 Yamaha dt125
1982 Yamaha 550 vision
1986 fazer 700
1983 Suzuki gs750e
1984 Honda v65 sabre
1985 Yamaha rz500
1985 kawi gpz turbo 750
2000 Honda sabre 1100
1998 Honda 800 interceptor vfr
2002 ktm rfs250 and drz 250
3, 250 cc kymco scooters
2014 bmw c650gt
2015 fz-07
sill have
2014 ctx1300
2014 dl1000 vstrom
gtmn is offline
post #7 of 29 Old 03-14-2016, 08:29 PM
Mines a J10?
neilking is offline
post #8 of 29 Old 03-14-2016, 08:53 PM
gtmn's Avatar
mine is a, 32920-31j10
112600 0021
nep144
cannot ride it relaxed if you are just riding it around it needs to be a bit over 2k
never ever had a bike like that
nope its not cuz its a race bred v twin
the bike should be able to pull itself along in rush hour traffic I should not have to pull the clutch in the entire time im in traffic
1975 Yamaha dt125
1986 fazer 700
1983 Suzuki gs750e
1985 Yamaha rz500
2014 bmw c650gt
2015 fz-07
sill have
2014 ctx1300
2014 dl1000 vstrom
gtmn is offline
post #9 of 29 Old 03-14-2016, 08:54 PM
I just went to Suzuki USA. Look for contact. Speak with customer service after hitting #1 and listening to recording when it asks to hit another number if you need more info.
714-572-1490.
I think the more people that do this, the more effective and the more urgency corporate might see this problem is. If we can get a whole "movement" or maybe even a "revolution" going, than I think the "establishment" might wake up and take us seriously
post #10 of 29 Old 03-14-2016, 10:56 PM Thread Starter
York's Avatar
ECU Part Numbers
STROMTROOPER Poll:
E28 Canada
E33 California
E14 Thailand
E21 E.U.
E24 Australia
E50 China
E99 Other Countries
NVDucati and Stroumph like this.
York
Last edited by York; 03-17-2016 at 02:00 AM. Reason: added dealer's address request
York is offline
