swmotech skidplate - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #1 of 11 Old 03-03-2016, 06:53 PM Thread Starter
swmotech skidplate
I am looking to purchase a skidplate for my strom. I like the sw motech but my only concern is that it attaches to the crankcase. If i take a good hit on the pan how much stress is that gonna casue to my engine case. any input on this would be great or if there is any other skidplates that you recommend. I wonder if i could leave the bracket that attaches to the crankcase of and not install it. would it still be sturdy enough. thanks
11KLR is offline
post #2 of 11 Old 03-03-2016, 07:38 PM
DerStrominator's Avatar
I have that skidplate on my 2014 Vee2. I have slammed it pretty good riding 2 up off road. No issues what so ever. This skidplate is worth its weight in gold. Lots of coverage!
It is not made for extreme off roading, but neither is this motorcycle.
Good luck!
richlandrick likes this.
DerStrominator is offline
post #3 of 11 Old 03-03-2016, 08:21 PM
Not Fragile's Avatar
The mounts to the engine are rubber isolated and are At 90 degrees providing a bend point. No issue IMHO
Not Fragile is offline
post #4 of 11 Old 03-03-2016, 08:25 PM
NSdave's Avatar
I have smashed mine a hundred times. No damage what so ever to the cases. It will eventually bend up and touch the exhaust. I just pound it back when I take it off to change the oil
This was after just one good trip
14' DL1000
NSdave is offline
post #5 of 11 Old 03-03-2016, 08:44 PM
The Suzuki factory accessory one mounts similar so if they are ok with that system the Motech one should be fine
stefman722 likes this.
jaba01 is offline
post #6 of 11 Old 03-03-2016, 11:08 PM Thread Starter
Nice that is good to hear. I Def like the look and build of the motel better than other brands. Thanks for the info
11KLR is offline
post #7 of 11 Old 03-04-2016, 09:06 AM
lilzip24's Avatar
I also have the plate on my '14 Vee2. Bashed it pretty good many times, zero issues whatsoever.
lilzip24 is offline
post #8 of 11 Old 03-04-2016, 11:44 AM
ToadRide's Avatar
When I owned an F800GS I had opted for an overpriced BMW skidplate. I was knocked off the bike by an exploding underground fuel tank cover (at least it popped off with the force of an explosion when I drove over it) that put a big ripped dent in the bottom and drove the plate into the oil filter. After removing it I found the mounts to be very soft brackets that bent easily. Only thing I could figure is it was Beemer's way of saving the crankcase by having the brackets collapse. Do the SWs mount that way?
ToadRide is offline
post #9 of 11 Old 03-04-2016, 09:20 PM
GotaV2's Avatar
We have the sw-motech skid plate/bashplate and removed the side bracing when we did last service and have had no issues.
Cheers GotaV2
2014 DL1000AL4-Glass Glacier White
OEM centre stand,chain guard,decals,SW-Motech,crashbars,pannier racks,brake,exhaust,master cylinder guards, footbase,ROX risers,Givi Hugger, Airflow, panniers,top box,PivotPgs,OmniC,Rad Guard,mirror extenders,3 Guardian Bells, Oxford HG,Tutoro, Zumo 590, PC8,Crees, G2,Grip puppies,helmet hook,SitnFly,2xBC tank bag & ring,Ventura HP,FP lowering kit,SPOT,Backoff,2 Tool Tubes,Sena 10s,Contour,Hwy pegs, 2 Aux plugs,MJM seat,levers,Barrett Exhaust,Stebal Horn,Personalised Rim tape,PP & Holder, Barkbusters & Led,smiley face
2012 DL650AL2-Pearl Mirage White "Sparkles" 2011-2014
GotaV2 is offline
post #10 of 11 Old 03-05-2016, 12:08 AM Thread Starter
Cheers GotaV2
thats what i was thinking. because it will be connected in the rear of the plate and also in the front to the crash bars. where the hell is gonna go lol
11KLR is offline
