Terminal Ground Connection Location - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 02-28-2016, 11:55 PM Thread Starter
York's Avatar
I would like to know where Suzuki connects the battery ground terminal on the Veek produced after May 27 2015?
After the recall it was connected on my bike to the engine hidden behind the engine sprocket cover.
Is this the same location on new bikes straight from the factory?
Ride - Life Is Too Short!
York
York is offline
post #2 of 5 Old 02-29-2016, 11:41 PM Thread Starter
York's Avatar
same spot?
OK, for the factory answer I'll wait until a 2015 bike owner joins this forum.
How about 2014 owners. Where is now your ground terminal connected after the recall work? Same spot as above? You can see it without removing anything.
York
York is offline
post #3 of 5 Old 03-01-2016, 02:24 AM
Stromaholic's Avatar
Mine stayed where it was, but my mates was relocated to the spot you're talking about
Never argue with an idiot.......they drag you down to their level, then beat you with experience!
Stromaholic is offline
post #4 of 5 Old 03-01-2016, 02:28 AM
We have a 2015 V2 and the earth connection started life on a pissy engine case bolt and was relocated and cable upgraded? to behind the clutch cover when the recall was done.
It would be safe to assume this location is now in current production models.
Paul and Dixie and our V2
DL1000A 2015. SW-Motec crash bars and skid plate,Givi Airflo screen,Givi rear Hugger,Factory low seat,Barkbusters with Storm guards,Factory Tank Protector, Factory centre stand,RadGuard Radiator Guard,home made top box adaptor plate with poverty top box,Factory hard panniers,Zumo390LM,TKC70's,windshield lowered 50mm with custom mounting plates,motopressor tyre inflator,Virgins breath in the tyres,Barrett exhaust,AWESOME rider and pillion.
We2V2 is offline
post #5 of 5 Old 03-01-2016, 04:36 AM
stu53's Avatar
My 2014 V2 had the earth connection relocated to behind the front sprocket cover as a part of the recall work.
DL1000A 2014
previously DL650K6
stu53 is offline
