ECM access - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By Stromaholic
post #1 of 5 Old 02-28-2016, 06:19 PM Thread Starter
triman11427's Avatar
ECM access
I don't have a manual but I need to get access to the ECM for a possible flash. Can someone direct me to where its located and how accessible it is. I was able to flash my 2013 S10 and it's been a great upgrade.
triman11427 is offline
post #2 of 5 Old 02-28-2016, 06:35 PM
The ECM is #8. The ability to change settings by flashing is severely limited. The Euro remedy has been replacement. ECU warranty replacement
post #3 of 5 Old 02-28-2016, 07:33 PM
NyMeTsFaN912's Avatar
It's hard to get to just like it is to get to the battery. There's a plastic cover that you have to remove to get to the ECU. There's two screws, one in the front and one on the left side of the cover. You have to remove the rubber band holding the tool kit which is simple but the hard part is getting that plastic cover off. I could not find any special way to do it other that reach from underneath the seat lock and try to work it out. Biggest PITA of any bike I've owned.
-John
NyMeTsFaN912 is offline
post #4 of 5 Old 02-28-2016, 08:01 PM
Stromaholic's Avatar
Remove seat.Remove toolkit. Remove 2 screws holding plastic relay tray. Move relay tray to the side exposes ECU. Unplug harness x2 and ECU is free. Allow 10 mins to do it the first time, then it only takes less than 5 after that.
Bad Dad likes this.
Never argue with an idiot.......they drag you down to their level, then beat you with experience!
Stromaholic is offline
post #5 of 5 Old 02-28-2016, 10:10 PM
If Suzuki is not going to do an ECU replacement under warranty, I would hope they would at least have some sort of reasonably priced exchange. Anyone know if there is any precedent for that?
-Gary
2016 GSX-S1000FA
2012 DR650SE
2011 Burgman 400
2007 Honda Helix
2013 V-Strom 650 - sold
G-Dub is offline
