Extra Key Cut - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 19 Old 02-26-2016, 01:47 PM Thread Starter
pats's Avatar
Extra Key Cut
I went to the local lockshop to buy an extra and ended up with one too short to work on the ignition but is OK for the luggage. They used a devise to see if there was a chip in the key plastic housing and said there was none. Has anyone had an extra key made, was it a national hardware chain?
pats is offline
post #2 of 19 Old 02-26-2016, 02:12 PM
NyMeTsFaN912's Avatar
What you should do is buy a blank from a Suzuki site or eBay that way you'll have no issues.
Lrobby99 likes this.
-John
NyMeTsFaN912 is offline
post #3 of 19 Old 02-26-2016, 03:14 PM
Go to a reputable locksmith. The one I went to had the blank on the wall and did a perfect job. I think I was out $10. I wouldn't trust a guy from a box store to cut a key I cared about.
Bville-Bud is offline
post #4 of 19 Old 02-26-2016, 03:34 PM
+1 Think the store that did mine was COPS
'08 Yellow DL650
Engine Guards; Bash Plate; Centerstand; 1" Bar Risers; Adjustable Lowering Links; OEM Top/Side Cases; EB Headlight Relay; OEM Handguards; Fork Brace; Piece a crap Windscreen; Broken Shift Lever (Tap/Bolt/Duct Tape); New Tires (but I coulda run on that plugged rear another 4k)
BumbleV is offline
post #5 of 19 Old 02-27-2016, 04:11 PM
An ILCO X276 SUZ16 blank works.
Pats, on yours, try filing or grinding the shoulders back so the key can slip farther into the ignition switch, if possible.
post #6 of 19 Old 02-27-2016, 06:37 PM
Here you go. Why take any chances.
https://www.ebay.com/ulk/itm/291624044358
-John
post #7 of 19 Old 02-28-2016, 09:41 PM
Ago
Ago's Avatar
I bought two of these last year for a few dollars, and had a local hardware store cut them:
Bland NEW Black Blank KEY Uncut Blade FOR Suzuki B King GSX1300BK GSX 1300 BK | eBay
Work perfectly... I still use the original, but these are good "just-in-case" spares.
Ago is offline
post #8 of 19 Old 02-28-2016, 09:55 PM Thread Starter
pats's Avatar
Thanks ptrider
pats is offline
post #9 of 19 Old 02-29-2016, 08:26 PM
Same here. He said it was a standard Suzuki car key blank; nothing special. Works just fine.
2014 DL1000 Khaki
IDRIDR is offline
post #10 of 19 Old 02-29-2016, 09:27 PM
Bikeless 4 now
Outbackwack's Avatar
I got into the practice of alternating my 2 keys every other ride so they both wear the same, but I really do need to get another spare... thanks for the reminder.
Get busy living, or get busy dying...
http://www.visitedstatesmap.com/image/AZCOCTILINIAKSKYMEMAMOMTNVNHNJNMNYOHPASDTXVTVAWVWY  sm.jpg
Outbackwack is offline
