Which rim design is stronger? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 11 Old 02-24-2016, 02:53 AM Thread Starter
The 10 spoke style of the Vee2 or the 3 spoke style of the Wee and old Vee...?
scharfg is offline
post #2 of 11 Old 02-24-2016, 09:19 AM
lilzip24's Avatar
I would say the 10 spoke would be more structurally sound than the 3 spoke as far as load bearing / impacts go...
lilzip24 is offline
post #3 of 11 Old 02-24-2016, 10:14 AM
I agree for overall strength & rigidity more spokes are better as as long as the spoke mass of the larger number of spokes is greater or equal to the smaller numbered spoke mass. Of course if the impact is directly on one of the three spokes the thick spoke would be stronger. That said, if an impact is solid enough to bend or break a cast spoke, the rim would be toast, so it may be a mute point.
Bville-Bud is offline
post #4 of 11 Old 02-24-2016, 11:22 AM
The heavy duty spoke wheels of the 650XT.
lilzip24 likes this.
post #5 of 11 Old 02-24-2016, 12:51 PM
Bugzy's Avatar
What kind of impact would it take to break a rim? I would think if your hitting something that hard, then likely your spine is broken too. Deflate your tires a little so they flex when hit and you can take some pretty significant bumps with any type rim before anything breaks.
A solid one piece rim would be the strongest, so it would make sense to me that a 3 spoke would be stronger than a 10 spoke, but maybe some rim flex occurs before the spoke breaks so the gaps are a good thing?
What are you planning to ride over that has you asking this question?
Bugzy is offline
post #6 of 11 Old 02-24-2016, 02:06 PM
The other thing to consider is the cross sectional thickness of the two wheels (old vs. new).
If they are the same thickness then the multi spokes should provide more rigidity. If not then there is no real basis for comparison.
I did bend the lip of my front wheel on a 1st gen 1K when it hit the rear of a car that cut me off, it was enough to deflate the front tire but the wheel did not crack.
I think the material used for these wheels is elastic enough to deform before it would break, excluding of course the extreme cases of impact.
A signature
sdmdm8 is offline
post #7 of 11 Old 02-24-2016, 04:10 PM
lilzip24's Avatar
Any kits to use the new '15 Wee's tubeless spokes?
lilzip24 is offline
post #8 of 11 Old 02-24-2016, 08:22 PM
Stromaholic's Avatar
I buckled a front wheel and bent the axle on my 2010 650 when I hit a 75mm lip left at roadworks. I also recall reading on a local motorcycle camping page, that one bloke shattered a front wheel on a Gen 1 650 not long ago.
Never argue with an idiot.......they drag you down to their level, then beat you with experience!
Stromaholic is offline
post #9 of 11 Old 02-24-2016, 09:10 PM
Bugzy's Avatar
Another thought is, if you hit something hard enough to damage/crack/break a cast rim, what damage would occur on a spoke rim for that same hit, it seems unlikely the rim would survive without any damage.
Bugzy is offline
post #10 of 11 Old 02-24-2016, 11:20 PM
Scott E. Bonds's Avatar
Besides loving his new bike (my favorite strom also)....which mooched the wheels from the Super Tenere.......Big B is correct. The more spokes you have the more the stress from an impact is spread out onto other parts of the wheel. Dirt bikes have spokes....every single one. You see any cast wheels in motocross.....think there is a reason?
The ten spoke is better than a 3 spoke. But, if bashing the wheels is in your future 32 or 36 spokes is the way to go, just be prepared to tension them some at first until they take a set.
Stromger likes this.
2007 Blue SuperVee 1000
2000 Red Honda XR 400r
Scott E. Bonds is offline
