Oil change interval - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 02-23-2016, 07:12 PM Thread Starter
pats's Avatar
Oil change interval
I have not yet found a manual, bike has 3200 Mi. and just serviced from dealer . How often is recommended for a change?
pats is offline
post #2 of 7 Old 02-23-2016, 07:36 PM
What model year is it? Suzuki changed the oil change interval in 2015 from 3500 miles to 7500 miles. If you just want to be good to the bike, you can use the latter figure. If you need to keep up the warranty, you need to follow the book. If it's a 2015 model, check with your dealer for an updated schedule as Suzuki changed the interval on the 2015 model during the model year.
post #3 of 7 Old 02-23-2016, 08:25 PM Thread Starter
pats's Avatar
Thanks its a 2014, would you know if the original filter would be imprinted w/ the suzuki logo? I bought from a non dealer and I want to make sure they changed the filter also, as closely as I can determine. Chances are if they did the oil change they would have used an non oem filter. Also what would have been the recommended mileage for the first oil change, man I need a manual! Thanks
pats is offline
post #4 of 7 Old 02-23-2016, 08:30 PM
Hard miles's Avatar
Yes OEM filters have the Suzuki markings. On my 2009 Vee 1 filter for 3 oil changes, 6000 km per oil change. The service manual, although expensive, is a plus.
Brian
Hard miles is offline
post #5 of 7 Old 02-23-2016, 09:08 PM
If the bike is out of warranty you can use a 7500 mile or 7.5 months oil change interval. One difference between Suzuki and aftermarket oil filters is the OEM uses 2 turns after gasket contact and other brands use 3/4 turn or one turn.
post #6 of 7 Old 02-23-2016, 10:55 PM
Brisky's Avatar
First would have been at 600 miles
Brisky is offline
post #7 of 7 Old 02-24-2016, 01:36 AM
Skew's Avatar
Are the newer storms using synthetic oil now? I have a 2011 model.
2011 DL650A
Skew is offline
