Oil Light Question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #1 of 11 Old 02-10-2016, 07:35 PM Thread Starter
kustard's Avatar
Oil Light Question
My bike is about to go in for it's 12K service and the recall service.
I have noticed though in the past two days that when I stop the bike after a ride that the oil light will flick on and off randomly.
When the bike is cold (or it's been off for 5 minutes after running) or when I'm riding the light behaves as expected, i.e. light on when engine off and light off when running. The oil level is fine.
I'll be mentioning it to the mechanic on Monday when the bike goes in for the service, but just wanted to ask if anyone had a similar thing happen to them and if it was indicative of an issue or if it is recall related.
Cheers.
Suzuki DR650 (2016) - Grey
Yamaha XSR900 (2016) - Blue
Sadly deceased: Suzuki VStrom DL1000 (2014) - White
Shiro Suzuki shijūha~tsu 白スズキ四十八 (White Suzuki forty-eight)
The Adventures of 69SIM - https://www.youtube.com/channel/UCzK0IIM_4zZjC3DF95GIBKA
kustard is offline
post #2 of 11 Old 02-10-2016, 08:02 PM
I can't tell by your description whether the bike is running when the light is flickering. If so, that's indicative of an oil pressure problem (or sensor/electrical malfunction). If the bike is off when this is happening, that's a whole 'nother crazy electrical issue.
kustard likes this.
blz2dwl is offline
post #3 of 11 Old 02-10-2016, 08:41 PM Thread Starter
kustard's Avatar
Yeah sorry, I re-read my description and it seems it was written by a moron hehe
The bike isn't running when it happens. When the engine is on the light functions normally. When I kill the engine that's when it happens. I'm pretty sure it's related to the recall issue. I'll just not ride the bike again until the service day and let them deal with it.
kustard is offline
post #4 of 11 Old 02-10-2016, 08:41 PM
Patico's Avatar
I'd have it checked by a competent mechanic just to be sure.
Once I had an old car whose Oil Light would turn occasionally because the wire would come off the oil pressure sensor and touch the car body. So many false alarms could make you ignore a real warning.
kustard likes this.
I is poor doge... I no know bikes!
Patico is offline
post #5 of 11 Old 02-10-2016, 09:11 PM
Bugzy's Avatar
That certainly sounds like a shorting wire someplace, or a loose connection, possible rust issue.
Hopefully you get a new harness, that should take care of it.
kustard likes this.
Bugzy is offline
post #6 of 11 Old 02-10-2016, 09:29 PM
The light should be on if the ignition is on and the engine not running. A marginal connection could cause a flicker under those conditions so it could be a connector involved in the recall.
kustard likes this.
post #7 of 11 Old 02-10-2016, 09:54 PM
Rolex's Avatar
Do these have a pressure switch or a level switch ?
My Yamaha MT09 (FZ09) has a level switch not a pressure switch.
I don't like it .....
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #8 of 11 Old 02-10-2016, 10:00 PM Thread Starter
kustard's Avatar
Not sure Rolex, I'll ask the mechanic anyway.
kustard is offline
post #9 of 11 Old 02-10-2016, 10:48 PM
It's an oil pressure switch.
kustard likes this.
post #10 of 11 Old 02-10-2016, 10:59 PM Thread Starter
kustard's Avatar
So I just rode home from work. Light worked as intended at work and the ride home.
At home I hit the kill switch, light came on as expected and stayed on. Reversed bike (a feat in itself) into the garage and as soon as I put the bike stand down the light started flickering. Bike can stay in the garage until service day on Monday.
Thanks for all the feedback guys
Cheers!
kustard is offline
