G2 throttle tamer - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 23 Old 01-18-2016, 01:02 PM Thread Starter
G2 throttle tamer
I'm thinking about ordering one for my 2014 dl1000. Will I need a new pair of grips and if so should I order the open end ones to install the device on the end of the grips
msvstrom1000 is offline
post #2 of 23 Old 01-18-2016, 01:56 PM
billyal33's Avatar
I have a g2 on mine. I just took the standard grip off and fitted it to the g2. A long thin screw driver up the bar end and some wd40 worked for me. I've just fitted Oxford heated grips and they where to tight on the g2 so I sanded off the knurled section of the g2 and all is ok. Either way you want the open ended grips as you'll need the handle bar end weights fitted to stop the vibrations.
billyal33 is offline
post #3 of 23 Old 01-18-2016, 04:58 PM
V2man's Avatar
G'day msvstrom1000,
Here's how e done ours, see post #44.
https://www.stromtrooper.com/dl1000a-...ted-grips.html
Cheers V2man & GotaV2
2014 DL1000A 2014 -
2012 DL650L2 2013 - 2014
2007 DL1000 "Bowser" 2009 - 2013
V2man is offline
post #4 of 23 Old 01-18-2016, 06:30 PM
Originally Posted by V2man View Post
G'day msvstrom1000,
FYI - you can link directly to Post #44 by simply clicking on the post # and linking to that URL.
Tipsy
TipsyMcStagger is offline
post #5 of 23 Old 01-28-2016, 08:46 AM
Simmo24's Avatar
Hi
I've got the Suzuki heated grips. willl I still be able to fit the G2 with those ?
Anyone already done this ?
Our greatest weakness lies in giving up.
Always try just one more time. -Thomas Edison
2014 DL1000 V-Strom AL4 Desert.
Simmo24 is offline
post #6 of 23 Old 01-28-2016, 02:05 PM
Patico's Avatar
My brother installed the Throttle Tamer on his Vee2 and is very happy with the results.
He used the original grips on it.
I is poor doge... I no know bikes!
Patico is offline
post #7 of 23 Old 02-11-2016, 11:27 PM
I checked with G2 ergo before ordering mine and they said when you order your throttle tamer ask them for reduced knurling for heated grips. Still a tight fit though.
disassembled is offline
post #8 of 23 Old 02-12-2016, 12:19 PM
cwjb's Avatar
Why are you guys using a throttle tamer? How do you like it ?
cwjb is offline
post #9 of 23 Old 02-13-2016, 03:25 PM
VtSTROM-K5's Avatar
Send a message via Yahoo to VtSTROM-K5
I am looking for the G2 Throttle tamer part # for the 14+ Vee-2
2014 V2 DL 1000 25 miles and Onward
IF I only Rode in Good weather..
I WOULDN'T get to Ride in Vermont.at ALL!
we have 2 types of roads in Vermont, Unpaved roads and decaying back to .............Unpaved roads..
2005 DL1000 98,547 miles and continuing in the hands of it's new owner
VtSTROM-K5 is offline
post #10 of 23 Old 02-17-2016, 08:53 AM
alon's Avatar
doesnt work with heated grips
2014 vee2- OEM:skid plate,heated grips,mirror extenders,centerstand. aftermarket:sw-motech: risers,trax 45L side cases 38L top case,pipe valve guard, kickstand foot enlarger. corbin/holshot heated seat ,MRA VarioTouringScreen,burkbusters storm,PC8, kaoko throttle lock, scorpion titanium slip-on, denali airbomb,scottoiler,denalli dx.pc5+autotune R&G:radiator guard, pipe slider K&N:air filter touratech:crashbars, ABS kill switch,dryspec tool tube,cyclops LED headlights,doubleback mirrors,helmet guardian,twowheels shorty levers,aftermarket off road rear brake lever,shorai lithium battery.
alon is offline
