Bridgestone BWs install - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 11 Old 01-11-2016, 11:39 PM Thread Starter
Ago
Ago's Avatar
I've been very happy with the OEM Battle Wings, so I decide to get a new set that I was planning to install over the winter; but after close inspection I'm thinking that the sidewall is so stiff on these tires that I don't know if I'll be able to install them using tire irons ー as I've always done in the past.
Has anyone here done a 'manual' install (no tire machine) with the BW 502 & 501s, or similarly stiff tires? Can it even be done without damaging the rims?
Ago is offline
post #2 of 11 Old 01-12-2016, 12:41 AM
tenny80's Avatar
I did it and I had never changed a tire before. I used the zip tie method and it worked like a charm. I've put 13k on it without any issues.
2018 Vstrom 1000
tenny80 is online now
post #3 of 11 Old 01-12-2016, 12:53 AM
Bugzy's Avatar
I tried it with my Harbor Freight setup and it was too difficult, so I just took the tire in. Very stiff sidewall as mentioned.
Bugzy is offline
post #4 of 11 Old 01-12-2016, 03:47 AM
Yup. These are nice but unfortunatelly good for only 13000 km or so.
Rick123 is offline
post #5 of 11 Old 01-12-2016, 11:13 AM
Vstrom N Me's Avatar
I have 7000 miles on mine and they are due to be changed. I'm 6'3 285 lbs so I think that has a look to do with the mileage.
If you change them - do you balance them?
Vstrom N Me is offline
post #6 of 11 Old 01-12-2016, 11:44 AM
i put a BW rear on my glee with tire irons. Yea, it was kind of a bitch, but if this almost-50-year body could do it, then pretty much any youngin could handle it. I wouldn't want to attempt it at 70, though.
I removed the existing weight and used Balance Beads. No issues.
2014 DL650 (sold)
2014 DL1000
mcrag is offline
post #7 of 11 Old 01-12-2016, 11:56 AM
tenny80's Avatar
You can use beads to balance them.
I didn't find them that hard to change but I have nothing to compare to. I will let you guys know how the pilot road 4 install goes.
2018 Vstrom 1000
post #8 of 11 Old 01-12-2016, 12:55 PM
I've been mounting my own tires for 6 years now. Haven't balanced one since my first couple, and haven't had one problem, not even on high performance machines. :beatnik:
cheapbastard is offline
post #9 of 11 Old 01-12-2016, 03:53 PM Thread Starter
Ago
Ago's Avatar
Originally Posted by tenny80 View Post
I used the zip tie method and it worked like a charm…
Zip ties… Does that really work? I've seen it done on some videos but it just doesn't look look like it would work on tires as stiff as these.
If it works, I might have to revisit the technique!
Ago is offline
post #10 of 11 Old 01-12-2016, 07:12 PM
tenny80's Avatar
worked like a charm. you need some big ones though dont piss around with linking a few together. 0 chance of putting a mark on the rim and with beads i had no issues.
2018 Vstrom 1000
