"Extra" Connector Near Tail/Brake Light Wiring? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 01-02-2016, 12:44 PM Thread Starter
Taped to the lead for the brake/tail light connector is a white two-wire connector. There are wires feeding the connector (White & Black w/White stripe) but no wires leading out. The male (or maybe female?) end of the connector has only black cavity plugs, depicted in second picture, where the wires would exit the connector. In other words, it's a connector with an input but no output.
Anyone know what this is?
Tipsy
Connector Taped to Brake/Tail Light Harness
Black Cavity Plugs in Connector
TipsyMcStagger is offline
post #2 of 8 Old 01-02-2016, 12:53 PM
It could be for adding lights or a top case with lights. I can tell you a brown wire is for a tail light hot, a white wire with a black stripe is for a brake light hot and a black wire with a white stripe is for ground.
post #3 of 8 Old 01-02-2016, 01:18 PM Thread Starter
Intersting. I just checked it with DMM (bike not running). The white shows 9v and dips slightly (8.75v) when the brake light is activated.
I did have the main brake light connector disconnected while checking the volatge but I don't think that should matter. As indicated above, the Brown wire shows 12v hot (tail light) and the White w/Black stripe shows 12v with the brake applied.
Tipsy
post #4 of 8 Old 01-02-2016, 03:46 PM
I checked the wiring diagram. The white wire goes to the ABS control unit. It may be some kind of diagnostic connector.
post #5 of 8 Old 01-02-2016, 05:35 PM Thread Starter
Interesting. I'm surprised this hasn't been discussed/identified previously. Or if it has, I couldn't find the info while searching.
Tipsy
post #6 of 8 Old 01-03-2016, 11:30 AM
scribe308's Avatar
Tipsy
Nice catch on this thing! When I was tapping into my tail light wiring for my front LEDs, I found the same thing and wondered what it was.
2014 Vstrom DL1000... der RödStröm
2002 Suzuki Intruder 1500 -gone
1999 Polaris Victory -gone
1976 Honda CB550 four -gone
1986 Honda XL650R -gone
1975 Suzuki RM250 -gone
1978 Suzuki DS100 -gone
scribe308 is offline
post #7 of 8 Old 01-03-2016, 12:02 PM
NyMeTsFaN912's Avatar
I think it's for a top case tail/brake light?
-John
NyMeTsFaN912 is offline
post #8 of 8 Old 01-03-2016, 12:27 PM Thread Starter
Greywolf referenced the wiring schematic.
Tipsy
