RANTING: Clutch design is unreliable in the Vee2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 64Likes
post #1 of 115 Old 12-31-2015, 10:49 PM Thread Starter
Patico's Avatar
Angry RANTING: Clutch design is unreliable in the Vee2
About 2 weeks ago, in the middle of a ride, my brother's Vee2 started leaking fluid from the lower clutch pump ( a.k.a. clutch release cylinder).
Long story short, he took it to the dealer for an emergency repair and found A LOT of mud, sand and stuff into the pump. It made its way inside the rubber seals and caused the leak. After quickly cleaning and refilling, the clutch system came back to operating condition. It worked fine since. Today, we received a new pump, and decided to replace it.
We took our time and removed maybe a spoonful of dirt from the chamber, and the pushing pin was coated with a thick layer of grease and mud. Whenever the clutch lever was pushed, dirt would go inside the rubber retainer in the engine, and when it was released, dirt would come inside the seal of the pump.
After a quick inspection, we found out the clutch push pin runs unprotected less than half and inch from the front sprocket. No wonder the clutch pump chamber was filled with the nasty stuff. The two draining holes in the cover plate are just not enough and the way the pin is constantly showered by the chain, is less than amusing.
Prior to reassembling. we decided to cover the pin with a rubber hose. The hose is long enough to cover the pin completely and won't move when the clutch is operated. It's loose enough to let the pin move freely but not too wide to get trapped by the chain.
Would you like to share your impressions?
Thanks.
I is poor doge... I no know bikes!
Patico is offline
post #2 of 115 Old 12-31-2015, 11:54 PM
Stromaholic's Avatar
I can see another recall.......
Never argue with an idiot.......they drag you down to their level, then beat you with experience!
Stromaholic is offline
post #3 of 115 Old 01-01-2016, 12:52 AM
this setup has been around for eons. They (Suzuki and all the other makers basically) are not about to change any time soon.
should be part of your monthly clean to do inside the countershaft sprocket cover.
Tom R
Big B and LittleMike like this.
"No Fear" just means you are not going fast enouh yet. life begins when you get outside that comfort zone.
Current rides
18 Busa
14 Vee2
13 Husky TR 650 Terra
08 Busa(now sold)
07Vee1(now sold)
02 Busa (sold)
97 TLs
97 TRX
92 NSr
Current Projects
38 BSA Goldie
Upcoming projects,perhaps by the time I get retired just maybe
83 GSX11(gunna be bought forward now as I don't have a going across frame 4)
71 A100
tomrux is offline
post #4 of 115 Old 01-01-2016, 01:09 AM
Tefloncandy's Avatar
I want to see a picture of your fix. Regardless of suggesting this be a normal maintenance item, I would like to see what a preventative fix would look like.
Adventurefiend likes this.
13' KLR 650, 06' GL1800
"No good decision was ever made in a swivel chair" George S. Patton
Tefloncandy is offline
post #5 of 115 Old 01-01-2016, 01:25 AM
Find some rubber tubing that's JUST a loose fit over the shaft, cut it to length, slip it over. Forget it.
The 650 has a similar problem but without quite such serious consequences.
Pete
PeteW is offline
post #6 of 115 Old 01-01-2016, 01:28 AM
Just had mine apart and cleaned the area thoroughly. The pushrod does seem rather "exposed", and grime will obviously work its' way along. I seem to remember an earlier Suzuki I owned had a casting separating the pushrod area from the sprocket cavity. What size hose did you use? I.D and O.D if at all possible. Cheers
post #7 of 115 Old 01-01-2016, 01:29 AM
Pete
Bring back the cable, I reckon!
Toto likes this.
post #8 of 115 Old 01-01-2016, 02:17 AM
Horrible title for thread, as the design is not unreliable. Make the mod like you did, use less gooey and sticky lube, and keep the slave area clean per regular maintenance. It is really that simple.....seriously.
post #9 of 115 Old 01-01-2016, 02:28 AM
8mm I.D fuel hose....problem solved!
post #10 of 115 Old 01-01-2016, 11:48 AM
IMO, none of these fixes or a 'monthly' preventative cleaning should be necessary on a bike these days. If this is indeed a problem, it's very disappointing.
Swlewers likes this.
MrMagoo is offline
