Vee2 fork spring rate - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By V-Tom
post #1 of 7 Old 12-30-2015, 11:04 AM Thread Starter
RichDesmond's Avatar
sdmdm8 was kind enough to send me a set of stock fork springs from his Vee2 so that I could rate them.
Broken up per inch of travel:
0.73
0.73
0.74
0.87
0.95
0.95
0.95
So basically a dual rate spring, 0.74 for the first 3", 0.95 for the last 3", with an inch of transition zone.
Somewhat on the soft side for a 500lb bike, but usable (if not ideal) for a lot of people.
Rich Desmond
RichDesmond is online now
post #2 of 7 Old 12-30-2015, 11:49 AM
Bikeless 4 now
Outbackwack's Avatar
I weigh 150# and I believe that is what the 0.95 rate is based upon. Race Tech has me calculated at 0.90 FWIW
Get busy living, or get busy dying...
http://www.visitedstatesmap.com/image/AZCOCTILINIAKSKYMEMAMOMTNVNHNJNMNYOHPASDTXVTVAWVWY  sm.jpg
Outbackwack is offline
post #3 of 7 Old 12-30-2015, 12:09 PM Thread Starter
If it was a straight 0.95 then it would be perfect for guys in the 200-250lb range. 0.90 is definitely good for you, and the stock springs are certainly close enough.
The progressiveness of the stock springs causes some problems, but I think for most people they will work ok.
Rich Desmond
post #4 of 7 Old 12-30-2015, 02:54 PM
Nice information fellers. I'm at 210 and like to load it up for a couple weeks of touring. It sounds like going to a straight 0.95 would be good for me.
2014 DL1000 Khaki
IDRIDR is offline
post #5 of 7 Old 01-16-2016, 11:23 AM
tenny80's Avatar
thank you for posting this! I find them a lot better then the stock ones in my 650. I'll likely replace mine when the first service is due. I take it you will be selling some straight rate springs at some point?
2018 Vstrom 1000
tenny80 is offline
post #6 of 7 Old 01-16-2016, 12:03 PM
V-Tom's Avatar
0.73
0.73
0.74
0.87
0.95
0.95
0.95
I found on my 2006 DL650 there were recommendations of getting .95 for my weight (which was probably around 240 lbs at the time.) I got them and found they were much too stiff for road work on rough roads. Might have been great for the track, I went down to .9 or .85 (don't recall which) and found it much better for rougher road use.
I weight a bit more than 240 now and have to say for these same roads I'm riding on the spring rate on my 2015 DL1000 actually feels pretty good although I do have to soften the damping a bit.
I know it's opinion and there are different strokes for different folks, but it just seems to me the a lot of the spring rates recommended are a bit much.
..Tom
LittleMike likes this.
My Opinion:
Vee or V= DL1000 before 2014
Vee3 or V3 = DL1050 2020 to?
My Stroms:
SMIDSY detailed report.
V-Tom is online now
post #7 of 7 Old 01-22-2016, 10:03 AM
Trackrider54's Avatar
At 230lbs in my birth clothes, the suspension feels really good. I have set the sag and had no problem getting it right without maxing out preload at either end.
____________________
Nashville, TN
2014 V-Strom 1000
Trackrider54 is offline
