SW Motech mirror extenders installation problem?! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 12-19-2015, 07:45 PM Thread Starter
hello,
Any one knows how to install these?
If you check the picture, the left looks correct but the right hand one does not align correctly with the mirror and I don't see how I can adjust it.
Thanks.
hfarinha is offline
post #2 of 4 Old 12-20-2015, 10:03 AM
NSdave's Avatar
If you loosen the 2 nuts on the mirror. The whole assembly can rotate to your desired spot Just pull the rubber boots up a little higher to see the second nut
14' DL1000
NSdave is offline
post #3 of 4 Old 12-20-2015, 11:51 AM
NyMeTsFaN912's Avatar
Remove the whole thing, screw in the bottom part, then screw the mirror on.
-John
NyMeTsFaN912 is offline
post #4 of 4 Old 12-20-2015, 09:23 PM Thread Starter
thanks for the tips. I got this figured out.
Cheers.
hfarinha is offline
