SW-MOTECH Sidestand Foot Enlarger - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #1 of 27 Old 11-30-2015, 09:13 PM Thread Starter
Tefloncandy's Avatar
I picked up the SW-Motech sidetand foot enlarger over the Thanksgiving holiday. It arrived today and I wasted no time getting it installed. This is a very solid, heavy and good looking bit of kit.
This one was as simple as it gets.
Package includes:
Top Plate
Bottom Plate
3 counter sunk screws
  • My install procedure:
  • Put the bike up on the center stand.
  • Remove the two rear counter sunk screws.
  • Loosen the front counter sunk screw.
  • Slip the foot pad over the stock kickstand foot.
  • Tighten the front counter sunk screw, but leave it a little loose.
  • Put thread locker on the two rear counter sunk screws and screw them into the foot pad. Be sure to just snug the screws up.
  • Unscrew the front counter sunk screw and put thread locker on it.
  • Now screw in the front counter sunk screw and snug it up.
  • In a crisscross pattern, tighten up the screws.
* No torque value was given for the counter sunk screws.
Notice the sloping profile...
Ridges for grip....
On the bike...
Bike on the sidestand...
13' KLR 650, 06' GL1800
"No good decision was ever made in a swivel chair" George S. Patton
Tefloncandy is offline
post #2 of 27 Old 11-30-2015, 09:23 PM
NeverSatisfied's Avatar
Looks good!
2012 DL650
2018 DR650
NeverSatisfied is offline
post #3 of 27 Old 11-30-2015, 10:05 PM
Bikeless 4 now
Outbackwack's Avatar
I have the Richland Rick on my 650 and it rubs the ground when raising the kickstand if the bike isn't totally vertical or more. It is much more square though. I may give this one a try. Thanks!
Get busy living, or get busy dying...
http://www.visitedstatesmap.com/image/AZCOCTILINIAKSKYMEMAMOMTNVNHNJNMNYOHPASDTXVTVAWVWY  sm.jpg
Outbackwack is offline
post #4 of 27 Old 11-30-2015, 10:16 PM
chicago's Avatar
I have the tourtech verson. these things really 'free' you. no more looking for a rock or something. no more watching for a moment to see if your bike sinks. just put it down and turn your back and walk away.
pvwheeler likes this.
14 tooth for me
chicago is online now
post #5 of 27 Old 12-01-2015, 11:43 PM
I have a home built Frankenfoot. I patterned after the plastic freebie at Laguna Seca raceway. Nice not to worry about soft stuff anymore.
notacop is online now
post #6 of 27 Old 12-08-2015, 07:05 AM
CAP10's Avatar
ALiexspress has knock offs for these for $12.00 on up. I ordered one and waiting for it to come in otherwise I just have the bigfoot type one to put under the stand. I ram a small zip tie through the front hole of it and I can easily place it under my stand as it acts as an exteneder.
CAP10 is offline
post #7 of 27 Old 12-08-2015, 12:08 PM
stromer's Avatar
On my 12 650 adv. I took a Richland Rick bolt on and threw away all but the steel base. measured the thickness of the steel base, then cut with a chop saw the same amount of thickness from the sidestand foot, then welded the new base on the sidestand leg. The result is a nice wide footprint, with out that annoying extra length and the bike standing too upright in some situations. A little more work, but well worth the outcome.
just give it a little gas, it will be ok !!!
stromer is offline
post #8 of 27 Old 12-08-2015, 01:47 PM
bosnjo's Avatar
I have Givi one and have never liked it. It's too big and too heavy. I had to cut off quite a lot of it and change side stand spring to stronger one so it's more or less OK now. If I knew it's gonna be so bad I'd purchase SW Motech one in fist place. It's much better looking and much lighter. Givi one has a lot of steel in it.
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
post #9 of 27 Old 12-08-2015, 02:23 PM
Can you send a link? I am curious to see the cheap version and i can't seen to find it myself
2002 DL1000: 75k miles. Bought at 50k miles.
1992 XJ600: Red, Very custom.
2002 Vespa ET4 150: The wife's ride.
Nelsonmd is offline
post #10 of 27 Old 12-08-2015, 05:57 PM
Ago
Ago's Avatar
Hmm, I have the Givi as well... never had any problems with its weight or size. I actually chose it because of its size; when on mud or gravel, the bigger it is the less likely it is to sink.
The only thing I did is to paint it black. Looks better on a black bike!
Ago is offline
