Fuel Gauge No Longer Reads Full - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 17 Old 11-26-2015, 11:37 PM Thread Starter
moe.ron's Avatar
My fuel gauge has stopped going all the way to full. Even after just filling up the last bar on the gauge remains unlit. This started about 5 tanks back, anybody else have this issue?
moe.ron is offline
post #2 of 17 Old 11-26-2015, 11:47 PM
flgolfer29's Avatar
Not here, 7600 miles so far.
Joe
flgolfer29 is offline
post #3 of 17 Old 11-27-2015, 12:04 AM
That happens when electrical connections inside the tank pick up a little extra resistance.
post #4 of 17 Old 11-27-2015, 12:12 AM Thread Starter
moe.ron's Avatar
Thanks for the response. What may cause that and is it an easy fix? Electric is not my thing, I can barely change a bulb.
moe.ron is offline
post #5 of 17 Old 11-27-2015, 12:20 AM
Connections get dirty, corrode, arc or lose springiness with age.
post #6 of 17 Old 11-27-2015, 12:36 AM Thread Starter
moe.ron's Avatar
Any idea which ones would be good to look at first? Isnt there one that is problematic under the tank or something?
moe.ron is offline
post #7 of 17 Old 11-27-2015, 01:11 AM
The usual problem in inside the tank. You need to take the fuel pump out of the tank to check.
post #8 of 17 Old 11-27-2015, 01:30 AM Thread Starter
moe.ron's Avatar
Yeah, looking back at my track record with a wrench I don't see that happening without some supervision!
Thanks for the tip. Hope you ate way too much food today!
moe.ron is offline
post #9 of 17 Old 11-27-2015, 04:29 PM
tenny80's Avatar
yikes, that's the first report that I know of with this issue on a 2014. I've got 22k km on mine and it still goes to full.
2018 Vstrom 1000
tenny80 is offline
post #10 of 17 Old 11-27-2015, 04:39 PM
Something you may want to try that is cheap and quick:
My first VStrom 1K was bought used with not many miles. Apparently, the gas got old and "varnish" and other crud coated the fuel gauge float. This made it heavier, and it sank rather than swim - making for a low reading. When this happened, fellow readers recommended strong fuel cleaner so I dumped in a bottle of Gumout or Techron (enough for a 15-gallon tank) and let it slosh around for a few days while I didn't put many miles on it. After several days, I took a good ride, and when I refilled, the fuel gauge magically jumped to "Full" and stayed there for 50 miles like it should.
Will this work for you? Maybe - maybe not. Not harm in trying.
Good luck.
Retired USAF MSgt (E-7)
Retired Rider - 2016 (3 V-Strom 1Ks, Concours, Burgman 650, 2 Honda 750 Nighthawks, and more over 40 years)
My website: www.RidingWV.com
VStrommer263 is offline
