How to release wiring harness connection from Fuel Tank Side Cover? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 16 Old 11-14-2015, 12:00 PM Thread Starter
flgolfer29's Avatar
Can someone tell me how to release the Wiring harness connection from Fuel Tank Side Cover? The bike is 2014 1000. I've check on-line but all the references are to earlier bikes without the harness connected.
I'm certain it is easy, however, the indention left at the tips of my thumb and finger beg to differ.
Thank you in advance!
joe
EDIT: to added a photo
flgolfer29 is offline
post #2 of 16 Old 11-14-2015, 01:18 PM
ToadRide's Avatar
Levering it up with some needle nose worked for me. Whatever you use you need to lever it out.
ToadRide is offline
post #3 of 16 Old 11-14-2015, 01:27 PM
Small bit standard screw driver, push in on release tab and pull on connector.
post #4 of 16 Old 11-14-2015, 01:57 PM Thread Starter
flgolfer29's Avatar
Thanks gentlemen, I ended up prying them out with standard screwdriver, it was a pain.
Once I put covers back on I will try pressing on the release tabs, hopefully they will still function properly after my removal method.
Thanks again.
Joe
post #5 of 16 Old 11-14-2015, 06:30 PM
NSdave's Avatar
Just pull on it
14' DL1000
NSdave is offline
post #6 of 16 Old 11-15-2015, 09:37 PM
kraut.burner's Avatar
Yep, ditto what everyone said.
Just finished removing my tank for a heated grip install. You have to pry around the base with a flathead screwdriver while pulling upward.
Definitely a PITA
kraut.burner is offline
post #7 of 16 Old 11-15-2015, 11:07 PM
VSTOM's Avatar
You can buy a tool at the auto parts store that is made to release these things.
It's a lot easier than a screw driver.
Lisle - Door Upholstery Remover
VSTOM is offline
post #8 of 16 Old 11-16-2015, 08:57 AM
Henk V's Avatar
Joe,
I asked the same question earlier. I resolved it as per this thread:
https://www.stromtrooper.com/dl1000a-...fasteners.html
Riding since 1995. Previously: Kawasaki KLE500, Suzuki GSX750F and Triumph Tiger 955i
Henk V is offline
post #9 of 16 Old 11-16-2015, 12:06 PM
ToadRide's Avatar
In that thread they are talking about the pushpin fasteners. These are different. I did pick up a forked end tool like a screwdriver with a bend in it that slides under the clip and pops it out.
ToadRide is offline
post #10 of 16 Old 11-17-2015, 02:28 AM
Henk V's Avatar
Maybe I should have added: See Post #15 on Page 2
flgolfer29 likes this.
Henk V is offline
