Accessory Wiring Harness? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 25 Old 06-15-2014, 11:43 AM Thread Starter
TRM
With Suzuki including heated grips and PIAA lights as "factory" acessories, does anyone know if they included some places in the wiring harness to plug these in? Or do they require leads back to the battery?
If they are "plug n play" i hope the aftermarket provides some other tools that can use these.
Thanks
TRM on the Northside of SA
TRM is offline
post #2 of 25 Old 06-15-2014, 01:03 PM
ToadRide's Avatar
I got right up to removing the tank trying to locate said harness but did not find it. Finally hardwired the new Zumo sistering up to the aux plug on the dash. My heated grips are Oxfords. Along with a great product and the right price, they come already to simply connect right to the battery.
ToadRide is offline
post #3 of 25 Old 06-15-2014, 04:30 PM
LittleMike's Avatar
Yes factory leads are there but you pretty well have to remove tank. Have installed factory grips using these not easy to find.
LittleMike is offline
post #4 of 25 Old 06-15-2014, 07:18 PM Thread Starter
TRM
Are there leads for accessory lights as well as heated grips? Are the installation guide for the grips out on the internet?
I didn't see anything obvious without removing the plastic, so I had a feeling I'd have to pull some plastic to see whats there. I'm really just curious as I'm working on my plans for adding more stuff.
Thanks, TRM
TRM is offline
post #5 of 25 Old 06-15-2014, 08:09 PM
ToadRide's Avatar
So LM. You have these leads? Love to see a pic of that. I pulled the tank, undid the rad and pulled it down and still found nothing. Went thru this with my Stelvio. Why do they do this. So they can laugh about it at lunchbreak?
ToadRide is offline
post #6 of 25 Old 06-15-2014, 08:40 PM
LittleMike's Avatar
Sorry no pics. but the leads are there tucked into the loom. They don't make them obvious probably only wanting deader installs. My dealers tech told me where to look. Only seen leads for the factory grips. Good luck
post #7 of 25 Old 06-15-2014, 08:56 PM
The connector is normally taped to the wiring harness. There might only be a lump visible.
post #8 of 25 Old 06-16-2014, 11:30 AM
ToadRide's Avatar
100 gold Doubloons to the first to discover them.
ToadRide is offline
post #9 of 25 Old 06-16-2014, 11:52 AM Thread Starter
TRM
So if I go with Suzuki lights or a kit from PIAA, Touratech, SW-mo, etc. I'm pretty much on my own? That may not be so bad, that way I don't really have to wait, and my last bike used the PIAA switch off the battery that worked fine.
I hate to spend almost $300 just for heated grips, but as a wiring dummy anything I can do to avoid cutting into the harness could be valuable. Luckily, I've got many months before the idea of 'heated' anything sounds good.
Appreciate the feedback. If anyone feels like doing a pictorial or video of a tank removal for grips (or otherwise), it would also be appreciated!
TRM
TRM is offline
post #10 of 25 Old 06-16-2014, 02:21 PM
ToadRide's Avatar
Have u not checked out the Oxfords? Far from $300. And installation for dummies.
ToadRide is offline
