Poll: Clutch chudder and idle hammer problems with the 2014's - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
View Poll Results: If you have MORE THAN 2000 miles on the odometer, have you experienced these issues?
Yes - (please describe in thread) 39 34.21%
No, runs perfectly 75 65.79%
Voters: 114. You may not vote on this poll
 6Likes
post #1 of 101 Old 06-13-2014, 03:23 PM Thread Starter
bogfro's Avatar
I'm considering buying a 2014 V2, but reading these reports about clutch chudder and idle hammer issues within the first 2000 miles is quite frankly starting to scare me away. I want to get a feel for the severity and magnitude of these issues.
So how many of you WITH AT LEAST 2000 MILES ON THE ODOMETER have had any kind of clutch chudder or idle hammer issues?
bogfro is offline
post #2 of 101 Old 06-13-2014, 04:37 PM
chirosyd's Avatar
2500 miles, all good here.
chirosyd is offline
post #3 of 101 Old 06-13-2014, 04:44 PM
Please answer the poll at the top of the page rather than posting results unless adding information beyond the poll questions.
post #4 of 101 Old 06-13-2014, 05:11 PM
GSP
Noisy V2 engine
After I had my first service done at 600 miles I noticed a noticeable hammer at idle and felt a kind of clanging vibration as the rpm's came up to the sweet spot of about 3800. I thought maybe they hadn't put enough oil in so I took it back to have it topped off. It sounded a little better after adding another 3/4 of a quart so I was hoping that was it and I took off on a 800 mile road trip. The bike performed well in all ways except for the engine. After warming up and riding for a 20 minutes or so the hammer and clank return and no matter how far I push my earplugs into my ears and turn up my music I still couldn't escape the unwanted vibrations. It feels like something is either not getting lubricated properly or that something is out of synchronization. It really seems to me like Suzuki needs to engineer a fix for this annoying development. It took 600 miles for the problem to surface and no test ride would have allowed the condition to be heard. Had I known then what I know now I would not have bought the bike.
It's in the dealership now getting looked into and I will let this thread know what I hear.
Allagash likes this.
GSP is offline
post #5 of 101 Old 06-13-2014, 06:19 PM
Only Idle Hammer
Started at 1000km. I don't think it is consequential. The dealer and mechanic and I reviewed the 'limp' the engine has at hot idle. We decided it was likely two things contributing: throttle body synchronization required because the airflow to each cylinder differs, probably related to different cam chain wear affecting valve timing AND very lean idle mixture causing combustion instability which can be heard at the exhaust. We decided that California requirements to adjust the TBS are probably wise. We will do the TBS adjust and set the idle at 6000km.
JohnB
2015 BMW F650GS
2014 Suzuki V-Strom 1000SEA
2013 Honda Giorno
1981 Honda Gyro
1975 Honda CT90 Trail
1974 Honda CB450K7
1968 Honda CB450K1
1964 Honda CB77 Superhawk
Hellcat is offline
post #6 of 101 Old 06-13-2014, 07:09 PM
Zone5's Avatar
I don't know if it applies here but the 1995 Honda VFR 750 had an idle hammer issue (just that year, funnily the 1994 didn't) that turned out to be end knock on the camshaft. Honda fixed it by getting a hole drilled which fed oil under pressure to the end of the camshaft. Anyway, the symptoms sound similar, including the time needed for the problem to develop, so I thought I'd mention it because a lot of us spent time chasing other causes.... Obviously it was irritating but not a requirement to have it fixed.
"Between two evils, I'll always take the one I've never tried before..."
Shiro Nakama #069
Suzuki: RF900 x 2, DRZ400E, DL650L2 ABS(sold), SV650SK9 ABS
Honda: CB750F2, VFR750/RC36 x 2, VTR1000 x 2
Yamaha: GTMX80, MX125, Virago250, Virago1100
Zone5 is offline
post #7 of 101 Old 06-14-2014, 03:47 PM Thread Starter
bogfro's Avatar
So far 4 "yes's" and 0 "no"'s. I'm not liking the way this is looking so far.
bogfro is offline
post #8 of 101 Old 06-14-2014, 04:50 PM
To be meaningful the number of owners of this bike on this forum is needed as if there's a 1000 owners and only 4 complain about the "problem" it's a different proportion if there's only 5 owners.
Oop North John is offline
post #9 of 101 Old 06-14-2014, 05:58 PM
Stoopy's Avatar
Not to mention the one guy above who said he's not having those problems but apparently doesn't know to click on the poll answer.
I'm not having any problems either at 2500 miles although I don't think it's going to do much to calm anyone down by saying as much. I'll add my vote though so there's at least a "1" count represented in some kind of baseline.
"Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge." - E.J. Potter
Stoopy is offline
post #10 of 101 Old 06-14-2014, 08:54 PM
Laava's Avatar
Good boy!.....
L4 DL1000 Black Strom No3
Laava is offline
