Hard Starting while cold - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 06-02-2014, 10:36 PM Thread Starter
After close to 2000 miles now I notice that starting the bike in the morning it takes quite a few hits on the starter button for it to start, after the initial start i barely hit the button and it starts. Don't know why it is starting to exhibit this type of behavior...Anyone else having this particular issue? other then that, bike is running great, no isues...
Jeff
Austin TX
jmackd1 is offline
post #2 of 14 Old 06-02-2014, 10:52 PM
chirosyd's Avatar
I have not had a problem with hard starting in colder weather. What are you idling at, and have you tried a little throttle upon starting? I assume you are using premium gas.
chirosyd is offline
post #3 of 14 Old 06-02-2014, 11:06 PM Thread Starter
By cold starting I mean the motorcycle is at ambient temperature, here in TX that is 70 degrees in the early morning. The owners manual states that if hard starting is detected, crack throttle 1/8"...Tried that during cranking the engine didn't seem to help.
jmackd1 is offline
post #4 of 14 Old 06-03-2014, 12:02 AM
Forget about the 1/8". Open the throttle until it starts to fire if it doesn't fire right away.
post #5 of 14 Old 06-03-2014, 07:13 AM
mine fIres right as up at the first touch of the button every time so far.
2014 khaki V2
01 KTM LC4 640 Enduro
Jake Mountain is offline
post #6 of 14 Old 06-03-2014, 10:29 AM
Here on Ice Planet Hoth, Edmonton - Canada, our summer mornings are typically 43-53 F. The Vee2 has close to 6000 km and fires up right away.
If you're fueling up at multiple stations, it's not the gas. You may need to do some troubleshooting or have the dealer take a look.
V-Gehts is offline
post #7 of 14 Old 06-03-2014, 01:31 PM
When you turn the key on, you need to wait for the fuel pressure to come up. Maybe you are too quick on the starter. Just a thought.
2012 Suzuki DL650AL2
1982 BMW R100RT
1985 Diamondback Ascent EX
boatin is offline
post #8 of 14 Old 06-03-2014, 05:17 PM
gryphon51's Avatar
Cold Starting???
2009 DL1000\ Scorpion Racing Skid Plate, Racetech Springs, Acerbis Hand Guards, Givi Engine Guards
Oxford Grips,
ALL BALLS BEARINGS.....Darkside Tire
gryphon51 is offline
post #9 of 14 Old 06-03-2014, 07:14 PM
ToadRide's Avatar
A brand new bike? it should just start. No need for throttle. It may mean that your fuel pump is not maintaining pressure and is leaking down (back?). Or it's not producing instant pressure as it should. Anyhoo...not right. get er in to the shop.
ToadRide is offline
post #10 of 14 Old 06-03-2014, 08:01 PM
Really folks, in warm weather, especially if the bike has a evaporative emissions control canister, fuel vapor can get into the intakes. Opening the throttle clears it right up.
