When to use traction control? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 05-28-2014, 07:58 AM Thread Starter
chirosyd's Avatar
Could someone with experience in traction control please educate me (us) on when to engage traction control. Should traction control be turned off when on dirt? Thanks for any insight.
chirosyd is offline
post #2 of 9 Old 05-28-2014, 08:03 AM
Not unless you have experience on dirt bikes.
You can't power slide with TC engaged, but basically if you are just riding through the dirt section and trying to not fall down , not a problem.
Pete
PeteW is offline
post #3 of 9 Old 05-28-2014, 10:35 AM
The TC when on setting 1 on the new Strom will let you slightly power slide in gravel enough to use wheel spin to help turn the bike. I have ridden mine probably 300 miles on gravel so far and setting 1 works well. It does not allow the bike to do a wheelie but it will let you get the front end light to get over pot holes. I would reserve setting 2 for rain use.
2014 khaki V2
01 KTM LC4 640 Enduro
Jake Mountain is offline
post #4 of 9 Old 05-28-2014, 12:54 PM
ToadRide's Avatar
I think traction control is fluff and I wish I didn't have to pay for it. Mine remains off. Hope I don't sound like too much of a braggart or an idiot, but I've been in a lot of weather over the years and, especially with today's modern tires, I've always been in control. (Hope this doesn't hex me.) Hard rain, I watch my speed or just avoid it. And in the dirt, who doesn't love to rocket rocks off the back wheel?
ToadRide is offline
post #5 of 9 Old 05-28-2014, 02:07 PM
Moderator
I low-sided a CB700SC on an onramp last year in the rain. There was silt and oil on the road and I had cold, hard tires. It happened just as I was accelerating through the apex. I bet traction control would have helped then.
Rudderfeet is offline
post #6 of 9 Old 05-28-2014, 02:52 PM
I know a BMW 1600 rider who thinks TC was the cause of his fall. He was on hard pavement going around a turn fast and hit some gravel. He thinks when he slipped in the gravel, the TC retarded the throttle so when he got through the gravel his rear continued the skid. It sounded reasonable and this guy is very experienced. He didn't think what he drove through was enough to cause the the low side under normal conditions.
2009 DL650
Stromburger is offline
post #7 of 9 Old 05-28-2014, 05:45 PM
xamdarb's Avatar
Big fan of the tc so far. Setting 1 will let the backend come out slightly on pavement without letting you lowside, setting 2 is great for the rain as previously mentioned.
I only turn it off on dry days when im am having some fun but I generally ride on tc 1.
tc 1 will let you bring the front wheel up although it pogos as it cuts power then regains power.
Yeeeehaaaaaw!
xamdarb is offline
post #8 of 9 Old 05-28-2014, 09:52 PM
I like TC2... easy run but damn good acceleration when I want to speed up...
Bernard101 is offline
post #9 of 9 Old 05-28-2014, 10:35 PM
My traction control came into play this morning on the way into work at 5:30am. Roads were damp, i took a right turn and got on the throttle like i usually do to start a merge onto the interstate, all the sudden the TC light on the dash started flickering, I had it on TC2. It wasn't obtrusive or anything, I was still accelerating, it just was keeping the rear wheel from letting loose, very good system in my opinion...
jmackd1 is offline
