Breaking in the 2014 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 39 Old 05-24-2014, 05:32 PM Thread Starter
Unless you follow the break-in procedure in the owner's handbook, which according to my research may be the worst way to break in a new bike; how do/did you break in your new DL1000? Thanks
390beretta is offline
post #2 of 39 Old 05-24-2014, 06:48 PM
ToadRide's Avatar
I rode it. Just ride it.
ToadRide is offline
post #3 of 39 Old 05-24-2014, 06:51 PM
stu53's Avatar
I can't see why Suzuki would recommend a break-in procedure that wasn't any good for the engine.
I'm sticking to it..... apart from the those times when I can't resist giving that motor an extra squirt just to feel that all that torque - something my old Wee just didn't have.
I'm lucky to live right on the edge of the city so there are plenty of good roads around and very little traffic or slow running to contend with.
Have logged 400kms now, and the motor just keeps getting smoother and more flexible. The brakes have also bedded in nicely and have heaps of power. 21km/l on the first tankful too!
I'm very happy with this bike.
stu53 is online now
post #4 of 39 Old 05-24-2014, 07:12 PM
My theory is the break in period is to break in the rider. The bike doesn't need it. It went through the gamut of rpms on a dyno before it left the factory.
post #5 of 39 Old 05-24-2014, 08:05 PM
I broke mine in exactly as the owners manual suggests, runs like a top approaching 2000 miles...I will follow the instructions from the company that designed and manufactured the motorcycle.
jmackd1 is offline
post #6 of 39 Old 05-24-2014, 08:07 PM
Laava's Avatar
I will come and break your bike in for you Beretta. But I will do the proper 5000mile break in procedure.
You're welcome!
L4 DL1000 Black Strom No3
Laava is offline
post #7 of 39 Old 05-24-2014, 08:22 PM
You actually followed the directions and instructions outlined by a lawyer. The only break in period is in your mind, yet many others will continue to follow the same scam.
post #8 of 39 Old 05-24-2014, 09:31 PM
Santah's Avatar
As succinctly put in Wiki:
The goal of modern engine break-ins is the settling of piston rings into an engine's cylinder wall. A cylinder wall is not perfectly smooth but has a deliberate slight roughness to help oil adhesion. As the engine is powered up, the piston rings between the pistons and cylinder wall will begin to seal against the wall's small ridges.
Operating the bike on a light throttle actually prevents the effective sealing of the new rings and barrel.
The manufacturer's line is unchanged from the days of cast iron liners and rings, and the lower grade plain bearings used in the past.
What they should really be saying, but won't, is: 'operate your bike gently and at low speeds so that you familiarize yourself with the bike, don't become another road accident statistic, or a potential litigant against us'.
Santah is offline
post #9 of 39 Old 05-24-2014, 11:16 PM
DaveinNC's Avatar
I ran the piss out of mine from first start, runs like a champ. Id swear I was running a big bore bike the way it performs.
"Dave"
DaveinNC is offline
post #10 of 39 Old 05-24-2014, 11:23 PM
I ran mine at varying rpm for about 40 miles on the highway on my way home from the dealer before I cranked it up to triple digit speeds about 3 times in my 2 hour ride home. I did keep the rpm's below 7500 for the first 350 miles but then it was on. It has 1600 on it now and she runs great. I did change the oil and filter the first time at 400 miles.
2014 khaki V2
01 KTM LC4 640 Enduro
Jake Mountain is offline
