Tail light, brake and rear turn signal wiring - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 36 Old 05-15-2014, 09:09 PM Thread Starter
Stoopy's Avatar
When I installed an AdMore Lighting kit to my top case, I found out that the wiring harness configuration for the DL1000A is very different than the DL650 and from what I have read, the legacy DL1000. After figuring it out, I thought I'd post what I found to work for me, in case anyone else needs this info and also lacks a service manual and schematic:
Looking at the taillight wiring, you'll see that the major difference is that there are three groups of wiring leading back to the tail, two groups have a connector that is easily accessed, while the other group basically runs straight through. The two groups with connectors use different styles - one is a 4-lead square-type connector and the other is an oval/round two-pin connector. Decoupling the connectors reveals that the group using the 4-lead square connector controls the taillights, while the two-lead round connector serves some other purpose entirely. Ergo, the straight-through wire group is your taillight and brake light.
Since all wire groups have a Black/White wire, it's easy to guess those are the ground wires, and this matches wire color coding on previous-year DL's I believe.
So here's what I came up with that worked for me:
Straight-Through wiring group:
White/Black.....Brake light
Black/White.....Ground
Brown.............Tail light hot
Square 4-pin connector- turn signals do not function when disconnected, brake and tail light works:
(one wire transitions to different color coding on other side of connector)
Connector "In" (from center of bike):....Connector "Out" (toward tail light):
Black .............................................Black .......................................Left turn signal
Black/White.....................................Black/White...............................Ground
Brown............................................. Grey.......................................Tail light hot?
Light Green......................................Light Green...............................Right turn signal
Round 2-pin connector - tail light, brake light, and turn signals still function when disconnected:
Black/White.......Ground
White...............???
I have a spare Eastern Beaver taillight wiring adapter for my Wee that I was hoping might work on this bike but the different arrangement rules it out, bummer.
"Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge." - E.J. Potter
Stoopy is offline
post #2 of 36 Old 05-15-2014, 09:33 PM
Except for the white wire, those are the same colors as other models use though the connectors are different.
post #3 of 36 Old 05-16-2014, 07:11 AM
Laava's Avatar
So does the white wire power the number plate light?
If not, where does it go? If you follow where it is routed to?
L4 DL1000 Black Strom No3
Laava is offline
post #4 of 36 Old 07-13-2014, 12:03 AM
Stromtrooper.com Sponsor
Jim Davis's Avatar
Hello owners of the new DL1000A. I now have new tail/brake and signal adapters. Connectors are different now so there's two new adapters for this bike. I'll be putting them online later today.
Also available will be spare connectors to plug in your aftermarket signals.
Jim Davis, Owner, Eastern Beaver Company:
http://easternbeaver.com/ - Motorcycle Electrics: 2007 DL1000 with 16/43 gearing, Superbrace, Tokico 4 Pot fronts, BackoffXP, H4 Dual Relay Kit, PC-8 Fusepanel, 2 Powerlet Sockets, Suzuki Centerstand - 1988 Africa Twin 650, 1990 VFR 750.
Jim Davis is offline
post #5 of 36 Old 07-13-2014, 09:33 AM Thread Starter
Stoopy's Avatar
Outstanding! Just what I was hoping for, I don't like poking holes in stock wiring with the posi-taps. URL Link is...?
If I were to redo my Admore turn/brake signal wiring properly with an EB adapter(s), anyone have ideas on what should/could be done about holes in the wiring insulation that are left after removal of posi-taps? Leave 'em and smear a little dialectric grease on 'em to fill the pits and avoid corrosion down the road?
Stoopy is offline
post #6 of 36 Old 07-13-2014, 09:38 AM
Use a little liquid electrical tape. Liquid Tape: Unity in Quality | Plasti Dip International is one of many suppliers. Check you local hardware or big box store.
post #7 of 36 Old 07-13-2014, 01:19 PM Thread Starter
Stoopy's Avatar
Thanks! I have some sitting in a cabinet in my garage and just keep forgetting it's there!
Stoopy is offline
post #8 of 36 Old 07-13-2014, 02:53 PM
Foget it for a few years after initial use and it may not be liquid any more.
post #9 of 36 Old 11-07-2014, 02:15 PM
TRM
Any advice on why the set up in the attached pic is not working? Its a BackOff XP and Eastern Beaver adapter? Is the wire mapping correct?
BackOff/Adapter
Red to Red
Black to Black
White/red stripe to Purple
Adapter Blue has a posilock on it just to protect the wire
I plugged in the adapter and only get running light, then i connected Red to Purple on the adapter and I get running and brake lights, which is why i thought that same configuration should work with the BackOff. I assume Blue wire is my low-intensity wire and is just a pass through?
Anyway, Signal Dynamics recommended bench testing the BackOff XP unit, so I guess I'll try to rig that up.
Thanks, TRM in SA
TRM is offline
post #10 of 36 Old 11-07-2014, 03:48 PM
For those of us who don't have a BackOff, what is it supposed to connect to by name?
Ground -
Brake light hot -
tail/license light hot -
