Idle knock and rough gearbox - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #1 of 47 Old 05-13-2014, 05:20 AM Thread Starter
Question Idle knock and rough gearbox
Does anyone else's bike have a distinct knocking noise at idle when the engine is hot? Turn the engine off for a few minutes and its disappears when the engine is restarted, so it's temperature related. The knock reduces in volume when the clutch lever is pulled in. It started at about 1000 km.
The gearbox is decidedly rougher on changing up than my 2008 650 has ever been. It's very smooth in the downshift. How's the gearbox on other folks bikes?
Deolali is offline
post #2 of 47 Old 05-13-2014, 06:06 AM
Laava's Avatar
Sounds like the old clutch basket glitch! Probably it will knock when cold too but may be slightly worse at operating temp.
Silly question, but have you made sure the oil is up to the full mark or near to it?
The 650 does have a very slick gearbox!
L4 DL1000 Black Strom No3
Laava is offline
post #3 of 47 Old 05-13-2014, 06:37 AM
I don't notice any knock at idle and the gear box is smooth up and down.
2014 khaki V2
01 KTM LC4 640 Enduro
Jake Mountain is offline
post #4 of 47 Old 05-13-2014, 06:42 AM
chirosyd's Avatar
Ditto here!
chirosyd is offline
post #5 of 47 Old 05-13-2014, 07:28 AM
Stoopy's Avatar
About 1800 miles now and I hear the slight knock at idle when hot, as has been reported by a couple of others. No problems with the gearbox though, it's been typical Suzuki smooth, there is a clunk shifting from first to second though. I do the same as on my Wee, push the earplugs in a little deeper so I don't think about the noise.
I have picked up an annoying squeak in the clutch lever that I need to take care of. But no shifting problems at all.
"Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge." - E.J. Potter
Stoopy is offline
post #6 of 47 Old 05-13-2014, 07:43 AM
That sounds more like idle hammer than clutch chudder. Idle Hammer Considerations and Experiences is about the Vee rather than the Vee2 of course.
post #7 of 47 Old 05-13-2014, 08:50 AM
Santah's Avatar
Its sounds like "ride more, worry less" to me. I have a really BIG issue with the 2014 V.
That large LCD speedo is really distracting as the digits change in my peripheral vision. It distracts me from the piston slap, cam chain rattle and all those other things.
Santah is offline
post #8 of 47 Old 05-13-2014, 09:56 AM
ToadRide's Avatar
Hey, I owned a Guzzi! Noises? Clunks? Don't even notice.
ToadRide is online now
post #9 of 47 Old 05-13-2014, 10:45 AM
Close to 1000 miles and no problems or strange noises reported here...
jmackd1 is offline
post #10 of 47 Old 05-13-2014, 01:41 PM
Stoopy's Avatar
Just a thought, have you tried dimming the display? It is on "full bright" by default, mine is now at 4/6 setting.
Stoopy is offline
