GPS holder mounted on windscreen - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 05-05-2014, 06:28 PM Thread Starter
RhinoVStrom's Avatar
I was looking if I could mount my GPS somewhere else. Why not on too the windshield
So drilled four holes in the screen and the RAM put on.
Have tested it and it works perfectly. Almost no vibration and the windscreen is still adjustable.
Have the test drive on video
GPS Mounted on Windscreen V-Strom 1000 L4 - YouTube
Greeting,
Peter
RhinoVStrom is offline
post #2 of 7 Old 05-07-2014, 01:35 PM
Mounting GPS
Hi Peter. Great idea. Looks like there would be some room to adjust the mount position. I'm 6' 2'' so I will try moving it a bit to the right to allow more view of the tach. Also might try a bit higher if the windshield allows. Your video is impressive. When you turned off the paved and went overland I was surprised how stable the GPS was. Thanks for the idea.
Ridesalot is offline
post #3 of 7 Old 05-07-2014, 08:23 PM Thread Starter
I've been to a manufacturer today who makes windshields. He said that the windshield asily can handle this construction.
@Ridesalot; If you use the ram mount, you can adjust You'r GPS. You don't have to change the position of the Mount. Than you have enough view on the tach.
Peter
post #4 of 7 Old 05-07-2014, 08:55 PM
GPS Mount
Good point. With both short and medium arms available I should be able to find the best position for me.
post #5 of 7 Old 05-08-2014, 10:53 AM
Santah's Avatar
Peter
Mechanical strength is not the issue generally. Always ensure with plastics that the holes are deburred (smooth edged). Holes should be also be oversize to prevent the metal bolts working on the plastic edges. Failure to do both may result in cracks developing.
Santah is offline
post #6 of 7 Old 05-08-2014, 08:48 PM Thread Starter
Santha,
This is also what the manufacturer said. Make the hole larger than the bolt that goes in. Have used a 4 mm bolt and drilled a 5.5 mm hole. I have used rubber between the RAM mount to absorb.
Peter
post #7 of 7 Old 07-03-2014, 02:34 AM
Stromtrooper.com Sponsor
richlandrick's Avatar
Brilliantly simple. I love it.
Kudos,
Rick
richlandrick is online now
