fuel gauge - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 05-04-2014, 07:25 PM Thread Starter
fuel gauge
Has anyone ran the fuel gauge so low that the last bar started blinking? I tried today, my indicated range said I had 7 miles to go, the last bar was not blinking but the gas pump icon was blinking. I filled up and it took 4.99 gallons.The tank hold 5.3 gal so I still had roughly 15 miles to go. The owners manual sez it starts blinking at 1.6 quarts, so I was really close. Basically when that last bar starts blinking you have to find a station quick!
jmackd1 is offline
post #2 of 16 Old 05-04-2014, 09:14 PM
Yup - I've had the last bar blinking with the fuel icon. Makes you drive faster to the nearest gas station
V-Gehts is offline
post #3 of 16 Old 05-04-2014, 09:49 PM
I ran mine to where it said I had 0 miles to go for probably 10 miles
2014 khaki V2
01 KTM LC4 640 Enduro
Jake Mountain is offline
post #4 of 16 Old 05-05-2014, 09:04 AM
Santah's Avatar
Yep, I've had the bar blinking. The fuel gauge is a bit of a puzzle though, as one day I arrived at work in the AM with it blinking, but when I left that arvo it showed two segments.
One day maybe somebody will find a way to accurately measure what goes into the tank and then measure what fuel goes out. Only then will these things be really accurate. The first part is the hard one, the second is the easier one.
Santah is offline
post #5 of 16 Old 05-05-2014, 03:48 PM
Stoopy's Avatar
If the fuel pump is cooled by the remaining fuel in the gas tank like it is on all previous V-Stroms, that can contribute to premature fuel pump failure.
I've had several fillups now but have yet to get the last bar to blink, I'm typically putting in 4.5 gallons when down to 1 bar and a flashing fuel icon...close 'nuff for me,
Sent from a terminal in the nurse's station when Nurse Ratchet wasn't lookin
"Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge." - E.J. Potter
Stoopy is offline
post #6 of 16 Old 05-05-2014, 05:47 PM
Banned
Originally Posted by jmackd1 View Post
I filled up and it took 4.99 gallons.The tank hold 5.3 gal ...
tank holds 5.8 us gals..
V-Strom (Suzuki DL1000) | Fuelly
JRWalker is offline
post #7 of 16 Old 05-05-2014, 06:01 PM
Not the 2014 Vee2. You are in the DL1000A 2014+ forum section......pay attention!!!!!
post #8 of 16 Old 05-05-2014, 06:12 PM
nvr2old's Avatar
Originally Posted by Big B View Post
Not the 2014 Vee2.
Or the 2012+ Wee
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is offline
post #9 of 16 Old 05-05-2014, 07:46 PM
Laava's Avatar
So is it a useable 5.3 gal or total actual capacity. Seems there would be no point having the bottom segment blinking with only 10 or so miles left?
On my 07Vee it has a 21 litre tank but I think it actually holds 22litres.
L4 DL1000 Black Strom No3
Laava is offline
post #10 of 16 Old 05-07-2014, 12:52 PM
Patico's Avatar
Originally Posted by Santah View Post
...as one day I arrived at work in the AM with it blinking, but when I left that arvo it showed two segments.
I had a GW250 Inazuma a while ago. It used the same fuel gauge display as the one used in the Wee2 and the Beakstrom.
I found out it would show a quite different reading if you start the bike laying on the side stand, or if you are mounted and standing vertical. Even 2 segments apart.
In the zuma, the reading would refresh about every 40 seconds or so, according to my observations, on a very lazy Saturday afternoon.
Probably the same will happen in the Stroms.
I is poor doge... I no know bikes!
Patico is offline
