Stall on down shift - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 58 Old 05-01-2014, 02:14 AM Thread Starter
xamdarb's Avatar
Stall on down shift
Hello,
I was wondering if anyone else has similar experiences with their bike.
I am getting a bit of sputtering / backfiring on engine braking (even light engine braking in the 3000 rpm range). Today I was coming up to a stop light and I down shifted from 4th into third and the bike stalled out! I will explain the procedure so its more clear. Coming to light around 65 km/h in 4th, let of gas, pull in clutch, slight bump on the throttle while downshifting to third to get the rpms up... Stall! I had not even released the clutch. Started it up before coming to a stop and has not happened again.
The bike also has a awkward idle when up to temp, tends to lope a bit. I am wondering if the ecu is acting up?
Anyone else?
Yeeeehaaaaaw!
xamdarb is offline
post #2 of 58 Old 05-01-2014, 04:11 AM
bosnjo's Avatar
Maybe position of side stand switch is not right and it's playing up as side stands vibrates a bit????
2017 DL1000 White
2014 DL1000 Red (sold)
2012 DL650 White (sold)
bosnjo is offline
post #3 of 58 Old 05-01-2014, 05:20 AM
+1 and try loose terminal connections before looking too deeply into ecu issues.
dogdaze is offline
post #4 of 58 Old 05-01-2014, 08:11 AM
On other bikes I've had a few strange symptoms when the battery leads weren't done up fully. Tightnening them up was cheaper than an ECU.
Oop North John is offline
post #5 of 58 Old 05-01-2014, 08:22 AM
I also noticed that the bike is a 2014 V-Beak, I would be back down the supplying dealer and get them to do it, and if a terminal was loose I'd want to know why was the dealer prep was charged (pdi) if not carried out?
dogdaze is offline
post #6 of 58 Old 05-01-2014, 02:37 PM
ToadRide's Avatar
Ya, nary a backfire out of mine. All is silk smooth right now. Of course that's with 500kms.
ToadRide is offline
post #7 of 58 Old 05-01-2014, 05:39 PM
Bugzy's Avatar
That sounds eerily like the old VStrom, and it needed a PC3 or PC5 to fix it.
Bugzy is online now
post #8 of 58 Old 05-01-2014, 07:06 PM
SERIOUSLY doubt that is the issue with this model.....all new injectors, ECM, extra plug, new internals. No bike is perfect but this is the first I have heard of this from the new Vee2, sounds like a trip back to the dealer is in order.
1997 Honda Valkyrie 1500 custom ďDoloresĒ
post #9 of 58 Old 05-01-2014, 08:11 PM
Banned
Are you using the correct fuel grade that the new engine requires?
FoxOrange is offline
post #10 of 58 Old 05-01-2014, 08:20 PM
Iíve already noticed the awkward, loping idle and Iím only at 162kms!!(Would LOVE to be able to manually adjust that idle!) I doubt itís an ECU issue, more like just one of those odd Strom peculiarities. My old í03 also had a tendency to stall on the throttle blip. This problem disappeared after the first 4 or 5 thousand kms and never occurred again. I'm hoping for a repeat performance with my new V2!
Graveleater is offline
