Idle adjustment? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 04-25-2014, 10:41 AM Thread Starter
Idle adjustment?
Anyone know a work around to adjust the idle speed? A quick inspection of my new Strom shows no adjustment point similar to that on my old ’03. The owners manual is no help, suggesting the bike be returned to the Dealer or repaired by a "qualified mechanic”. WTF??
Graveleater is offline
post #2 of 9 Old 04-25-2014, 11:21 AM
I'm sure it has the same setup as the Glee. The idle setting is computer controlled for emissions reasons. It will never need to be touched unless a sensor is changed that affects the computer input, like a TPS adjustment. Then a simple reset procedure will put it back in range. I'll also bet the need for TBS adjustments will be a thing of the past. Somebody with a service manual can probably back that up.
post #3 of 9 Old 04-25-2014, 12:27 PM Thread Starter
Thank-you! I wasn’t aware of that set-up on the 650’s. I guess as long as it works properly, the factory computer settings will have to do!
post #4 of 9 Old 04-26-2014, 08:52 PM
Mine seems like it idles a little too low, about 1100rpm , it's at the bottom of what the owners manual sez, 1100 - 1300rpm. Guess the computer knows best....! no adjustment....
jmackd1 is offline
post #5 of 9 Old 04-29-2014, 08:22 PM Thread Starter
Mine too! That was what concerned me! Hopefully it won’t be a problem but I sure wish I could give it a little ‘nudge’.
post #6 of 9 Old 04-29-2014, 08:47 PM
Maybe somebody with a service manual can look up the idle speed reset procedure. If nothing else, it will assure the idle speed is where it was designed to be.
It may be the same as for the 650 but it may be totally different.
This is the 650 procedure.
1) Turn the ignition switch to the OFF position.
2) Remove the seat.
3) Connect the special tool to the dealer mode coupler and turn
its switch to ON position. (a paper clip jumper on the correct terminals will also work)
4) Turn the ignition switch to the ON position.
5) Turn the ignition switch to the OFF position.
6) Then, wait more than 5 seconds.
NOTE:
The ISC valve automatically is set at the PRE-SET position.
7) Turn the special tool to the OFF position and remove it from
the dealer mode coupler or remove the paper clip.
post #7 of 9 Old 03-17-2015, 12:44 AM
tenny80's Avatar
I find mine idles low as well, my wife actually told me it sounds like it's going to stall tonight.
2018 Vstrom 1000
tenny80 is offline
post #8 of 9 Old 03-18-2015, 12:06 AM
moe.ron's Avatar
Mine idles around 1100, sounds OK I think. I am not one of those "qualified mechanics" mentioned above though.
moe.ron is offline
post #9 of 9 Old 03-19-2015, 03:55 PM
Mr. Black's Avatar
I've noticed with mine that the idle is different with the clutch in (in gear) or out (neutral).
I'd say around 200rpm difference.
Steve,
2014 Vee2.
Givi Airflow, Givi crash bars.
Oxford Adventure grips.
Hindle Carbon Muffler.
Touratech handguards, Touratech skid plate.
Rox 1"x1" risers, RK Gold X-ring chain.
Mr. Black is offline
