1000 km maintenance - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 34 Old 04-22-2014, 10:29 PM Thread Starter
xamdarb's Avatar
1000 km maintenance
Hello all,
I have recently rolled over 1000 km and was looking at the required maintenance for this interval.
1. Throttle play, it suggest 4mm max I believe, mine is more in the range of 8-10mm. Is this the amount of forward and back play your throttle has while sitting without pulling the cable (free play?)
2. Throttle valve synchronization..... what is this? Why does it have a * beside it?
3. exhaust and chassis bolts. Anyone have the torque specs on these? Know of a manual that has them?
Yeeeehaaaaaw!
xamdarb is offline
post #2 of 34 Old 04-23-2014, 10:52 AM
When I had my Wee several years ago, the throttle had lots of play as delivered and was somewhat snatchy.
I took almost all of the play out to about 1 or 2 mm and all was good after that.
I don't know why lots of bikes are delivered with so much play in the cables.
Toto is offline
post #3 of 34 Old 04-23-2014, 01:02 PM
My V2 is the same way, way too much free play in the throttle
2014 khaki V2
01 KTM LC4 640 Enduro
Jake Mountain is offline
post #4 of 34 Old 04-23-2014, 01:11 PM
chirosyd's Avatar
Could someone let us know how to check and correct for excessive throttle play?
chirosyd is offline
post #5 of 34 Old 04-23-2014, 04:26 PM Thread Starter
xamdarb's Avatar
Read the owners manual, it explains it in sec 6
Yeeeehaaaaaw!
xamdarb is offline
post #6 of 34 Old 04-23-2014, 04:28 PM
chirosyd's Avatar
Thanks! I will look tonight.
chirosyd is offline
post #7 of 34 Old 04-23-2014, 06:39 PM
I have the shop manual. The throttle valve synchronization at 1000km is only required on California bikes. The procedure requires the use of the Suzuki Diagnostic System to open a setup function on the ECM. Then the primary throttle stops are adjusted to get an equal vacuum at 1200 RPM. The last step is to trigger a "Relearn" function via the SDS. Probably 1-1/2 hour shop procedure, a lot of which is to strip off trim/tank/air filter etc to get at the intakes.
JohnB
2015 BMW F650GS
2014 Suzuki V-Strom 1000SEA
2013 Honda Giorno
1981 Honda Gyro
1975 Honda CT90 Trail
1974 Honda CB450K7
1968 Honda CB450K1
1964 Honda CB77 Superhawk
Hellcat is offline
post #8 of 34 Old 04-23-2014, 06:53 PM
Hellcat, that you for your reply, good to know that the throttle sync is only for the california bikes...
jmackd1 is offline
post #9 of 34 Old 04-23-2014, 10:26 PM Thread Starter
xamdarb's Avatar
Hellcat, Does it mention the torque specs for exhaust and chassis bolts? What company makes the manual?
Yeeeehaaaaaw!
xamdarb is offline
post #10 of 34 Old 04-23-2014, 11:30 PM Thread Starter
xamdarb's Avatar
adjusted my throttle slack today, like hellcat said, it makes a big difference. Not sure why they come off the floor with such a crazy amount of play, have mine down to around 3 mm now feels a lot better.
Yeeeehaaaaaw!
xamdarb is offline
