Heated Grips - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 04-10-2014, 09:28 PM Thread Starter
PhilS14's Avatar
Heated Grips
So, I understand there are pre-wired keyed hot factory wire connectors to hook up the "Suzuki" heated grips. I haven't bought the very reasonably priced factory heated grips ($310 - HA!), bit I'd like to find those connectors.
Anyone know if this is true and where they're at??
2014 VStrom ADV 1000 - The VBeak!
See my life on the new VStrom at VBeak.Blogspot.com
PhilS14 is offline
post #2 of 10 Old 04-10-2014, 09:34 PM
Not sure where located, but I highly recommend the Symtec grips.
post #3 of 10 Old 04-13-2014, 06:02 PM
ToadRide's Avatar
Oxfords are great.
ToadRide is offline
post #4 of 10 Old 04-13-2014, 07:01 PM
LordSmoke's Avatar
Oxfords are great. The factory connector used to be behind the radiator, IIRC.
2014 BMW R1200GSW (APR14 - )
LordSmoke is offline
post #5 of 10 Old 04-13-2014, 07:49 PM Thread Starter
PhilS14's Avatar
Dealer is requesting install PDF on the '14 grip kit. I'll advise once I get it.
PhilS14 is offline
post #6 of 10 Old 04-14-2014, 01:19 AM
I had the Oxfords installed on the Vee2. Riding at near 0 degrees Celsius, fingers are warm without the hand guards in place - still waiting for the SE part to arrive
V-Gehts is offline
post #7 of 10 Old 04-14-2014, 08:07 PM
ToadRide's Avatar
is there an existing switch for the heated grip add ons?
ToadRide is offline
post #8 of 10 Old 04-14-2014, 08:36 PM
I installed heated grips from Cycle Gear and the factory connector was neatly and tightly tucked behind the radiator. If you don't want to splice into the connector you can purchase a wire,horn,lead and connect that way.
Reference this article as it has all the info you need.
http://stromtrooper.wikispaces.com/B...1000+%26+DL650)
nwfirerider is offline
post #9 of 10 Old 04-14-2014, 09:23 PM
The stock bikes have a connector, but no switch.
post #10 of 10 Old 04-14-2014, 09:56 PM Thread Starter
PhilS14's Avatar
Was yours a 2014? I know the pre-2014 models had wiring behind the radiator waiting to be used.
PhilS14 is offline
