Cam Gear Noise - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 29 Old 04-01-2014, 06:52 PM Thread Starter
Cam Gear Noise
I am about to pull the trigger on the new Vee2...but when listening to the Youtube stuff I hear quite a bit of cam gear noise...somewhat annoying.
I do wear earplugs.
Comments please?
Toto is offline
post #2 of 29 Old 04-01-2014, 06:58 PM
The bike is flawless. Any imperfection is just your imagination. La, la, la, la.
Of course it makes gear noise, its a partially gear driven valve system.
Get a louder exhaust then you won't be able to hear it.
Joe S.
'14 HD FLHR
'12 Concours
'11 DL650
'01 HD FXD
'09 HD XR1200
'79 BMW R100
Joe S. is offline
post #3 of 29 Old 04-01-2014, 06:58 PM
Love that sound, and know I am not alone either. Always aftermarket exhaust options, that will mute the gear wine a bit.
post #4 of 29 Old 04-01-2014, 07:03 PM Thread Starter
I am thinking ear plugs will take care of most of it.
Toto is offline
post #5 of 29 Old 04-01-2014, 07:05 PM
kiwi_outdoors's Avatar
cam gear noise
I do wear earplugs.
Comments please?
try listening to a Ducati with its Desmodronic valve system
Current Bike: 2007 ABS Wee, rebuilt forks with Cogent DDC, Elka rear shock, tapered roller steering stem bearings, fork brace, Admore top box lights, LED side-only turn indicator lights, Powerlet outlet, frame sliders, Givi windscreen, Givi top box.
Prior Bikes: 2003 EX250, 2007 DL650 (non-ABS)
kiwi_outdoors is offline
post #6 of 29 Old 04-01-2014, 07:06 PM
xamdarb's Avatar
I do wear earplugs.
Comments please?
Lots of cam gear noise, I personally like that noise. Mine has a slight knock at idle when warm.... I do not like that noise.
Yeeeehaaaaaw!
xamdarb is offline
post #7 of 29 Old 04-01-2014, 07:08 PM
Another music to my ears sound!
post #8 of 29 Old 04-01-2014, 07:16 PM
Stoopy's Avatar
I do wear earplugs.
Comments please?
The bike makes that noise all the time, if it really does bother you I would not get the bike. I always wear earplugs (Hearos) and cannot hear it when riding expect at stoplights but that's OK as I LIKE the sound quite a bit. Without earplugs it is very noticeable and almost sounds like supercharger belt whine when getting on the throttle at speed (quite cool!). But it's always going to be there every start, every shutdown, and every red light, make no mistake.
"Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge." - E.J. Potter
Stoopy is offline
post #9 of 29 Old 04-01-2014, 07:22 PM Thread Starter
Thanks for the informative answer Stoopy.
As long as I can't hear it much running down the road, I am ok.
I wear earplugs also, all the time.
They are EAR SOFT GRIPPERS by 3M.(foam)
They are like the older Earsofts with little ridges to help seal and they really work good.
Reviewed by webBikeWorld...most excellent and comfy FYI.
BTW, went several dealers today in the greater Toronto are with a bud...no one got one on display yet....bummer.
Toto is offline
post #10 of 29 Old 04-01-2014, 07:26 PM
Stoopy's Avatar
As long as I can't hear it much running down the highway, I am ok.
In that context, your earplugs would have to be pretty weak for you to hear it over wind noise and the nice thrum of the exhaust.
And you are very much welcome, happy to help.
Stoopy is offline
