ABS - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 03-31-2014, 10:56 PM Thread Starter
ToadRide's Avatar
ABS
Just want to talk about the non switchable ABS. My present and previous bikes were switchable. And I know for a fact that, having forgotten to turn it off on a couple of downhill switchbacks, I actually lost it having "no brakes'. Pic attached.
Someone did say to 'just pull the fuse' to knock out the ABS. If it is that simple could you not make that circuit switchable?
ToadRide is offline
post #2 of 3 Old 03-31-2014, 11:20 PM
Sure. Eastern Beaver has an ABS cutout switch kit for the Wee or Glee. There is even a way to wire a switch so ABS can be turned off and back on again without having to cycle the ignition switch. Proper ABS on/off switch
The Veek is probably wired so the same thing could work.
post #3 of 3 Old 04-01-2014, 12:20 AM Thread Starter
ToadRide's Avatar
eggcellent
ToadRide is offline
