oil filter - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 35 Old 03-30-2014, 11:39 PM Thread Starter
xamdarb's Avatar
oil filter
Does anyone happen to know what oil filter this bike takes? I am due for a change and would rather not buy a Suzuki filter $$$$$$$.
Yeeeehaaaaaw!
xamdarb is offline
post #2 of 35 Old 03-31-2014, 12:42 AM
Typically, OEM oil filters are reasonably priced, considering they are built to a very high standard.
The DL1000A maintenance schedule calls for oil filter replacement every 18,000 km, with the exception of the first change at the 1,000 km mark. Oil changes are recommended every 6,000 km.
For me, the cost of a Suzuki OEM filter is a small price to pay to maintain this fine piece of machinery.
V-Gehts is offline
post #3 of 35 Old 03-31-2014, 01:42 AM Thread Starter
xamdarb's Avatar
you never gave me the filter number. I personally don't believe brand name filters such as Suzuki and Yamaha are any better than say a good fram filter.
Fram for instance runs a company based on manufacturing filters, they should be more than able to manufacture a top notch filter.
On a side note, how much oil have you guys burnt on your first few hundred km?
I am surprised at how much mine has burnt, I was well below the low line after only 200 km?
Yeeeehaaaaaw!
xamdarb is offline
post #4 of 35 Old 03-31-2014, 01:49 AM
Fram is owned by the Rank Group of New Zealand. Their cheapest are pretty junky. Their better ones are good, but overpriced compared to others. WIX are good. So is Hiflo HF138. No, oil filters are not all the same. A defective oil filter will ruin an engine...not common but possible. I'd rather save a coupl'a dollars on something with a less costly downside.
post #5 of 35 Old 03-31-2014, 02:19 AM Thread Starter
xamdarb's Avatar
Who is to say that these brand name filters are even made by the company's they endorse? They could very well be outsourcing companies such as fram to make the filters for them.
Besides Canadian tire has waaayyyy better hours then my local dealer, some of us work a 9-5 these days (dealer closes at 5).
Yeeeehaaaaaw!
xamdarb is offline
post #6 of 35 Old 03-31-2014, 08:08 AM
Stoopy's Avatar
At 400 miles (not km) I haven't burned any that I can see, I'm still at the full mark. As another member here pointed out, are you checking with the bike on the sidestand or while holding the bike straight up and down?
"Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge." - E.J. Potter
Stoopy is offline
post #7 of 35 Old 03-31-2014, 09:11 AM
chirosyd's Avatar
I am not aware that breaking in a new engine will burn oil. I did not find this with my '11 Wee during the breaking in process. I will be riding my Vee2 this week, and keep an eye on the oil level.
BTW, is anyone changing the oil after the first 50-100 miles or so? I have been reading articles on breaking in engines, and there is much controversy. Some say that in spite of the excellent manufacturing process, there is still small metal pieces that accumulate in the oil filter. In addition, I have read that
we should stay in 2nd, 3rd and 4th gear, speeding up to 65 m.p.h. with abrupt slowing down for the first 1-200 miles to properly break in the engine. That makes the most sense to me after my reading of different opinions. Any thoughts?
chirosyd is offline
post #8 of 35 Old 03-31-2014, 10:52 AM
cpd419's Avatar
the only bike I ever had that burned oil (out of at least 30) was my HD xr1200. I bought it new and it used a couple of quarts in the first couple thousand miles and then just quit using it. Common for that engine apparently.
cpd419 is offline
post #9 of 35 Old 03-31-2014, 10:59 AM
Stoopy's Avatar
Originally Posted by chirosyd View Post
...In addition, I have read that
That sounds like the infamous "MotoMan" break-in procedure. While some people swear to it, I'll only consider it once "MotoMan" starts providing warranty on the engine. Until then, the break-in procedure per the engineers who actually designed and developed the bike is credible enough for me. The manual does say to not hold a constant speed, but to vary engine speed and that's what I also observe on my new vehicles as well. Drives people around you on the freeway a little crazy as you are always continuously gradually accelerating and decelerating but, oh well...
Stoopy is offline
post #10 of 35 Old 03-31-2014, 11:27 AM
chirosyd's Avatar
Stoopy,
You are correct, and nailed my reading of MotoMan and some "other guy".
I do like to keep to O.E.M. filters and replacement parts, so I should stick with Suzuki's engine break in directions.
chirosyd is offline
