Speedometer accuracy - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 25 Old 03-26-2014, 09:43 PM Thread Starter
Anybody can say if the speedometer is accurate or a bit overspeed as it is for the old and the new 650 ?
Bernard101 is offline
post #2 of 25 Old 03-26-2014, 10:00 PM
Stoopy's Avatar
It's been on my list to confirm but without a GPS mounted yet I cannot say, but based on observation so far I suspect it is a bit overspeed.
"Ignorance is a powerful tool if applied at the right time, even usually surpassing knowledge." - E.J. Potter
Stoopy is offline
post #3 of 25 Old 03-26-2014, 10:20 PM
The 2012+ overstates speed by about 7.5 percent. I installed a SpeedoDRD over the winter and input a -7.5% adjustment. It now matches Garmin speed and those radar signs exactly. It will take some time to unlearn the habit of estimating an 8% adjustment in my head while riding. I can sure use the mental bandwidth!
dkayak1 is offline
post #4 of 25 Old 03-26-2014, 10:44 PM
Brockie's Avatar
Using GPS my 2010 WeeStrom speedometer indicates 108kph (67mph) at a true 100kph (62mph), over stating by 8%, on stock Trailwings.
Brockie is offline
post #5 of 25 Old 03-27-2014, 07:05 AM
acormier7's Avatar
Cycle World tested the VEE2 in this month's mag. 60mph indicated was actually 56mph.
Art in Edmonton
14 DL650
03 DL1000 SOLD
acormier7 is offline
post #6 of 25 Old 03-27-2014, 07:53 AM
Stoopy's Avatar
Good to know - it felt like it was reading a skosh high.
dkayak, I wonder how to tell if that gizmo would be applicable to the Vee2? Any guess what the odds might be? EDIT: probably best to ask 'em directly now that I found 'em, thanks for the lead!
Stoopy is offline
post #7 of 25 Old 03-27-2014, 08:59 AM
There's a lot of info on these devices on the forum. Most users seem very pleased. Took me a while to cough up $70 just to fix an 8% error but now that it's done I appreciate it a lot, more so than expected. Very easy to install and program too. GW provided excellent guidance on finding and opening the wiring connector. Vee2 may use a different one. The mfr can tell you.
dkayak1 is offline
post #8 of 25 Old 03-27-2014, 11:17 AM
ToadRide's Avatar
It seems to me that most, if not all bikes have the speedo error built in. And, tho I have queried this extensively I have never stumbled on the real reason why. Government conspiracy? Subtle way of keeping our speed down? Who knows. But it is so common that it has to be built in deliberately.
All to our ongoing annoyance.
ToadRide is offline
post #9 of 25 Old 03-27-2014, 01:57 PM
In many countries they can't sell you a motor / bike with an under-reading speedo, so it's easier to sell one which does over-read. I guess it's so that if you keep below the posted speed limit as indicated on your speedo, then you can't be breaking the limit.
Oop North John is offline
post #10 of 25 Old 11-09-2014, 04:23 PM
I know most speedometers on bikes are overly optimistic. I have yet to calibrate with my gps, I find myself all too often flying along at 140-150kph according to my speedo.
Robdek is offline
