stronger rear spring? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 02-10-2014, 12:31 PM Thread Starter
Do I assume that being 220 pounds..plus Trax boxes, gear, etc, adding up to around 330 pounds...give or take...the rear spring would have to be...upgraded?
Thanks for your insight(s).
Mr. Pete----->
aging hippie
mrpete64 is offline
post #2 of 15 Old 02-10-2014, 12:59 PM
I don't know if anyone knows for sure yet, but its a pretty fair bet that you would benefit from setting it up for your weight and your extras.
Joe S.
'14 HD FLHR
'12 Concours
'11 DL650
'01 HD FXD
'09 HD XR1200
'79 BMW R100
Joe S. is offline
post #3 of 15 Old 02-10-2014, 01:09 PM
tmcgee's Avatar
Yes, you'll definitely benefit from a stronger spring, and better yet, a reworked or aftermarket shock. Personally, I've had a HyperPro on two Vstroms and would buy a third.
tmcgee is offline
post #4 of 15 Old 02-10-2014, 05:10 PM
Have to be upgraded.....NO......good idea....probably.
post #5 of 15 Old 02-10-2014, 05:17 PM
DaveinNC's Avatar
Im 220, cranked the preload all the way up front and rear, seems good for me. When I load it down for the first trip we will see how it handles an extra 75 lbs of camping gear.
"Dave"
DaveinNC is offline
post #6 of 15 Old 02-10-2014, 05:44 PM
Bully's Avatar
I've got Trax luggage on my 2012 Vee and weigh about the same as you and I went from the OEM spring rate of 8.2kg/mm to a 11.6kg/mm spring on my rear shock. It would be nice if the Vee2 had a rear shock heavy enough to cope with our needs but I doubt it.
It'll also be also interesting to see what affect aftermarket adventure style luggage, such as Trax etc, will have on the Vee2's aerodynamics/handling characteristics.
Bully is offline
post #7 of 15 Old 02-11-2014, 01:52 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
I'm 230 and upgraded both front and rear springs. That along with a fork brace (ours of course) made a huge difference. I suggest trying a Wilber's rear shock spring on the stock shock with the rebound dampening backed off 1/4 turn from full.
Check Sonic springs for the front. The have a calculator on their site that is very helpful.
Seriously, these changes, along with a fork brace, make a huge difference in how a V-Strom behaves. It goes from a wallowing long legged dual sport to feeling like a tight sport touring machine.
You can always go back and buy the shock without the spring later.
richlandrick is offline
post #8 of 15 Old 02-12-2014, 09:03 AM Thread Starter
thanks!!
Mr. Pete----->
aging hippie
mrpete64 is offline
post #9 of 15 Old 02-12-2014, 09:07 AM
You could just lose some weight, carry less crap and save yourself a small fortune changing suspension and on top of that your heart will thank you
I see it as a win win situation all round, but that's just me.
dogdaze is offline
post #10 of 15 Old 02-12-2014, 11:03 AM
hunt1moore's Avatar
I'm also 230 lbs. I did the calculation based on both of us at 373lbs. Recommended fork springs are 1.2 kg and shock at 17.66 kg. (basically the stiffest)
Is that the correct way to calculate? We will be riding together 95% of the time.
PC-V, TRE, CR8EIX , ECM, K&N, RDL, PR4, PC-8, EB H4, WERKS, Madstad 22", 17/43 gearing, AdventureTech: Fork brace, shelf, mirror extenders, SpeedoDRD, wheel spacer, Head's-Up voltage monitor, Goldwing pegs, Sonic 1.1, Wolo Bad Boy, ExTuff Helmet Hook.
hunt1moore is offline
