Error in DL1000 electrical diagram - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 4Likes
  • 3 Post By greywolf
  • 1 Post By gryphon51
post #1 of 3 Old 01-06-2013, 12:47 PM Thread Starter
There is a misplaced connection dot in the fuse box of wiring diagrams I've seen for K4 and K5 DL1000s. The K3 was okay. I've put a green dot where the connection appears in the manual. That spot should be a crossover. The connection should be where I've added a red dot. (on the left for the colorblind). The common wire feed to those fuses should be the orange wire.
motorworks, mushu and Ennsync like this.
post #2 of 3 Old 04-18-2014, 11:54 AM
gryphon51's Avatar
Only you would be proofreading electrical schematics for Stroms GreyWolf....
The masses thank you for your dilligence
motorworks likes this.
2009 DL1000\ Scorpion Racing Skid Plate, Racetech Springs, Acerbis Hand Guards, Givi Engine Guards
Oxford Grips,
ALL BALLS BEARINGS.....Darkside Tire
gryphon51 is offline
post #3 of 3 Old 03-31-2019, 07:48 AM
dudu's Avatar
Great info. Thanks!
Insert witty comment here
dudu is offline
