Did Suzuki honor your Service Bulletin 35? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 18 Old 01-13-2011, 04:14 PM Thread Starter
Those of you that own a '04, '05 and '06 1K's, did Suzuki honor the Service Bulletin 35 ECU replacement after your warranty expired? I'm the second owner of my 1K w/ 2700 miles on it and I called Suzuki regarding this and they told me since it was out of warranty, the Service Bulletin 35 didn't apply! I thought recall's had nothing to do with warranties? My 1K is a '05.
austin03 is offline
post #2 of 18 Old 01-13-2011, 04:29 PM
RedBean25's Avatar
Safety recalls do not have anything to do with warranty. However, TSBs are typically only implemented if there is a problem with the bike at which time it is at the owner's expense unless under warranty. So you will have to pay for it to be done since you are out of warranty.
2012 Triumph Tiger 800 Roadie, White
2007 DL650 Blue -- SOLD
Stromtrooper Offroad Club Member #22
Blue Strom Club Member #17
My Strom's Experience:
RedBean25 is offline
post #3 of 18 Old 01-13-2011, 05:21 PM
That would be a big NO.
Illinois is offline
post #4 of 18 Old 01-13-2011, 05:40 PM
BWC
Have an 05 Vee that has had the ECU upgrade done under warranty with the previous owner.
Was done at just under 10,000 km in the first year.
The previous owner said the engine quit in a left turn against traffic, part way through an intersection, not fun.
I would think a power commander would be the better way to go as the ECU is pricey if not covered by warranty.
If you decide to go with the new ECU with the upgraded mapping it does cure the problem as mine has 70,000 km with no fueling issues. Bernie 05-DL-1K
BWC is offline
post #5 of 18 Old 01-13-2011, 06:03 PM Thread Starter
Awww, ceeeeerapp! I do have a PCIII on it now but it would have been nice to have the corrected ECU. After doing a TBS, installing a PCIII and Gipro/TRE a while back, that pretty much took care of the 3k - 4K sputter. Also changing the drive sprockets from 17/41 to 16/43 helped ridability. Also installed speedo healer after changing sprockets.
austin03 is offline
post #6 of 18 Old 01-14-2011, 11:56 PM
RedBean25's Avatar
Originally Posted by Illinois View Post
Got in my first ride after installing a new chain and 16/43 sprockets from Blair. At 17,000 miles both sprockets were still in good shape (had swapped to a 16 front earlier). Chain was stretched some and started to kink (take it off pavement/ watercrossings from time to time). New set-up seems more responsive and much smoother. Feels like a brand new scoot for not a whole lot of money.
Holy threadjack batman!!! Methinks someone posted in the wrong thread.
post #7 of 18 Old 01-15-2011, 12:02 AM
Oops :mrgreen:
Illinois is offline
post #8 of 18 Old 01-18-2011, 05:46 PM
Casper's Avatar
The service bulletin doesn't say it has to be under warranty. It just says they'll replace it free of charge.
[url]www.ohioriders.net[/url]
Casper is offline
post #9 of 18 Old 01-19-2011, 08:10 PM
Boy talks too much....
slowoldfart's Avatar
Alkeehaul and posting just dont mix....
slowoldfart is offline
post #10 of 18 Old 01-19-2011, 08:21 PM
It is a dealer issue....not Suzuki.
