Need Advice - '12 V1000 Starter Switch Assembly Installation - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
  • 2 Post By teevee
  • 1 Post By Rolex
post #1 of 10 Old 11-20-2019, 05:32 PM Thread Starter
Big Boy's Avatar
Hello All,
Well my starter switch 'Bit the Dirt' and would no longer consistently/reliably start the bike. Not good. I ordered a replacement (schematic below). It looks to be a simple plug and play affair.
I assume that the tank (as close to empty of fuel as possible) has to come off for the exchange.
However any and all tips/tricks from the collective specifically about accessing the connection/plug would be greatly appreciated!!!
Thanks in Advance!!!
W. C. Fields
Big Boy is offline
post #2 of 10 Old 11-20-2019, 10:00 PM
teevee's Avatar
picture speaks 1000 words. looks like the airbox needs to come out, and for me, that was the BIGGEST pita.
richlandrick and Gert like this.
'08 DR650, '07 DL1000
teevee is offline
post #3 of 10 Old 11-21-2019, 09:01 AM Thread Starter
Big Boy's Avatar
You Da Man!!!!!!!!!!!!
Yeah, removing the tank is the one thing I've been dreading! I've removed it once just after I acquired the V in March this year to check/change the air filter as well as inspect the plugs. It's a bulky heavy sucker even with all the fuel I could remove. I can just picture me dropping it.
Many Thanks for the Schematic!!!
W. C. Fields
Big Boy is offline
post #4 of 10 Old 11-22-2019, 07:42 AM
teevee's Avatar
i was looking (not very closely) at my bike last night, and i'm thinking that you may be able to get to the connection by removing the right side cowling, which would definitely be less a pita than removing tank and airbox.
teevee is offline
post #5 of 10 Old 11-22-2019, 11:54 AM Thread Starter
Big Boy's Avatar
Many Thanks!!! But I think the phrase PITA covers accessing the connection pretty well
I've just got to get off my backside and dig into the situation.
W. C. Fields
Big Boy is offline
post #6 of 10 Old 11-22-2019, 08:53 PM
Rolex's Avatar
With the air box you should have the lid off, put the driver socket and bar into the front clamp and use a little tape to the air box to support it & keep it there while you fit the boot.
Fit and clamp the front boot first then position and clamp the rear boot, too easy...
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #7 of 10 Old 11-23-2019, 10:12 AM Thread Starter
Big Boy's Avatar
Hi Rolex,
Just wondering if we're still talking about the Ignition Switch / Handlebar Coupler ???
W. C. Fields
Big Boy is offline
post #8 of 10 Old 11-23-2019, 06:29 PM
Rolex's Avatar
Teevee mentioned he found removing the air box a real pita and it looks like you may need to remove it too.
Getting a tool onto the front clamp can be frustrating because it's quite hard to see, by fitting the tool before you start reassembly that part is easy.
By having the lid off you get to easily move the boots around from the inside so they slip home without drama.
Gert likes this.
2014 V2, Snoopy
Rolex is offline
post #9 of 10 Old 11-23-2019, 08:34 PM Thread Starter
Big Boy's Avatar
Many Thanks!!!
W. C. Fields
Big Boy is offline
post #10 of 10 Old 11-23-2019, 10:10 PM
teevee's Avatar
i found that the hardest part about getting it back together was getting all the second air crap reconnected. so, i bought the eliminator kit and voila! no more second air shit!
also, a really long screwdriver and quasi-needle nose pliers helps.
teevee is offline
