Spark plug wire chowdered - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 6Likes
post #11 of 18 Old 11-07-2019, 03:42 AM Thread Starter
Originally Posted by RLBranson View Post
While you are waiting for the part to come in you can cover the exposed wire with a thick layer of silicone adhesive for insulation. also cover the exposed wires in the wire harness.
Cheers
RLBranson
I coated the wire with a thick coating of 3M polyurethane caulking which is very tough and sticky. After it had hardened enough, I wrapped it with multiple wraps of really high quality electrical tape, then buttoned it up. It runs fine, so i'm just going to leave it at that for now. No more backfiring so the partially displaced boot was the problem there. I did try tugging on the wire coming out of the coil and it's a no-go. So I assume it's replaceable as a unit. It's about 65 bucks.
divebobber is offline
post #12 of 18 Old 11-07-2019, 03:45 AM Thread Starter
Originally Posted by Yarz1 View Post
Are you the original owner of the bike? When was the last time you had the tank off? In your photo, just south of the sparkplug wire, there is a blue spot. That looks like a rub mark, and not from a critter. Any chance something is rubbing on your wires, resulting in that condition?
The DIY silicone fix is a good idea. There is actually silicone hose at AutoZone that looks like heater hose which you could slit and slide over as a guard. I did the silicone repair once to a VW Golf that I owned. It ran great except when it rained, at which time it would simply die. One night (do it in the dark because it helps to see the sparks) with no rain, I ran the engine and then took a spray bottle of water to it. You only need a slight mist. My coil covering looked like it had been shattered based on all of the wayward electrical sparking, yet you couldn't see anything in the daylight. A slathering coat of silicone helped, but I eventually replaced the coil.
I just bought it a couple of months ago, so the critters were probably not from my yard. Never had this problem with any other vehicle including my Wee. First time having the tank off, and I don't think anything is rubbing on it. If you look closely, you can see that it's definitely little bite marks on the wiring.
post #13 of 18 Old 11-07-2019, 03:47 AM Thread Starter
Hey thanks for the great replies everyone! Great advice!
post #14 of 18 Old 11-08-2019, 05:55 PM
Charlie1982's Avatar
You could also try putting one or two dryer sheets in your under-seat tray, if you want a preventive measure there. Iíve heard that mice donít like the smell of those.
Charlie1982 is offline
post #15 of 18 Old 11-09-2019, 02:53 AM Thread Starter
I'll try it. Thanks.
post #16 of 18 Old 11-10-2019, 09:01 PM
on the Madura many of us have changed plug wires.
Kevin Tee.
2005 DL1000 Vstrom
2 - 1986 GV1200 GLG Madura
2 - 1985 GV700 Madura
2012 Husqvarna TR650
KevinTee is offline
post #17 of 18 Old 11-11-2019, 02:26 AM Thread Starter
It seems that the application of a thick coating of 3M polyurethane sealant followed by a thick wrap of high quality electrical tape has done an adequate job. The bike is running fine.
post #18 of 18 Old 11-11-2019, 12:15 PM
chicago's Avatar
having experienced similar problems in past I use mouse traps + peanut butter. protect your vehicles and reduce the population. win win.
they are also a good indicator that there are mice about.
14 tooth for me
chicago is offline
