High RPMs at idle 2007 vee. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 10-19-2019, 01:45 PM Thread Starter
When I pull up to a stoplight or stop sign the bike doesn't return to idle rpm range. It hovers at about 3k rpms. If I rev the bike and release the throttle the Rpms drop to normal idle range. The throttle appears to be seated where it should be and not hung up or dragging on the handguards or switches. What may be the cause? Thanks in advance for any advise.
Bigstromrider is offline
post #2 of 5 Old 10-20-2019, 04:35 AM
Linkages on throttle bodies sticky would be my bet.
Cheers Tom R
"No Fear" just means you are not going fast enouh yet. life begins when you get outside that comfort zone.
Current rides
18 Busa
14 Vee2
13 Husky TR 650 Terra
08 Busa(now sold)
07Vee1(now sold)
02 Busa (sold)
97 TLs
97 TRX
92 NSr
Current Projects
38 BSA Goldie
Upcoming projects,perhaps by the time I get retired just maybe
83 GSX11(gunna be bought forward now as I don't have a going across frame 4)
71 A100
tomrux is offline
post #3 of 5 Old 10-20-2019, 12:28 PM
When you rev it up to 5000 or so in neutral and gently let go does it hang up at 3000? Can you twist the throttle back to normal RPM? If so, the first place I would look is the throttle tube. Do you have heated grips? If so do you know what make/kind they are? The kind of heated grips that tape onto the throttle tube where you slide the grip over can melt and distort the plastic throttle tube causing it to drag.
gdrew is offline
post #4 of 5 Old 10-20-2019, 09:34 PM
teevee's Avatar
T.
P.
S.
'08 DR650, '07 DL1000
teevee is offline
post #5 of 5 Old 10-23-2019, 12:06 AM Thread Starter
Thank you teevee and Tomrux. I will look at both and post the outcome.
